Old 12-21-2020, 07:13 PM   #1
jflogerzi
jflogerzi's Avatar
Minimum Tire Tread SX2 for Track day
I got a set of SX2's I want to try and burn off completely.
Fronts have between 3-4MM of tread and rears have between 4-5mm tread left. Is this enough to get another track day with setup in signature minus boosted(going back to NA+ E85 setup)
2013 Series 10 FRS #553
Old 12-21-2020, 07:17 PM   #2
CSG Mike
CSG Mike's Avatar
Yes it is.
You will hit base compound at 2/32" (wear bar), and it'll be pretty evident when you do, as grip will drop dramatically.
jflogerzi (12-21-2020)
Old 01-01-2021, 08:56 PM   #3
jflogerzi
jflogerzi's Avatar
To bump this thread...
I did some re-measurements and noticed fronts are now under 3mm. I have a new set waiting in the wings. Rear is between 4-5mm. Can I just put 2 new tires in the front and then swap out the rears after the 20th at big willow?
Old 01-02-2021, 12:42 AM   #4
Jdmjunkie
Drives: Scion FR-S 10 Series
I would put the low tread depth on the front and run the new ones on the back.
Jdmjunkie is offline   Reply With Quote
Old 01-02-2021, 01:59 AM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I'd shoot myself with that much understeer putting the new tires on the back.
If you're wearing out fronts quicker then rears then rotate and use up the set you've got imho, check them after every session and stop if you hit the cords.
ineedyourdiddly
Icecreamtruk (01-03-2021)
Old 01-02-2021, 09:33 AM   #6
jflogerzi
jflogerzi's Avatar
I would put the new tires up front
Old 01-02-2021, 09:55 AM   #7
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Having a sub par tire setup at Big Willow is not a good idea.
Put all new tires on
TommyW is offline   Reply With Quote
The Following User Says Thank You to TommyW For This Useful Post:
CSG Mike (01-12-2021)
Old 01-09-2021, 11:39 PM   #8
jflogerzi
jflogerzi's Avatar
I decided to get the most out of these tires. Got an auto cross day to kill the tires and I will swap before big willow
The Following User Says Thank You to jflogerzi For This Useful Post:
Minimum for track day. fatoni Tracking / Autocross / HPDE / Drifting 40 01-19-2018 01:04 PM
WTB: one stock FRS tire with 60%+ tread [FOUND ONE - THANKS!] bluesman Want-To-Buy Requests 0 11-30-2016 03:24 PM
Tire Tread Life for Michelin Pilot Super Sport ARTBRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 11-23-2016 01:59 AM
Tire Tread white_knight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 04-16-2013 09:35 PM
