Old 01-06-2021, 12:47 PM   #1
spdbydesign
spdbydesign's Avatar
Drives: 2010 Nissan GTR
SBD announces the new 54mm G500X Ball-Bearing Turbo Kit!
We have been privately testing our latest ball-bearing turbo option, which spools INCREDIBLY fast on the FA20. I would go as far as to say it drives like a N/A V8 vs a turbocharged engine. The turbocharger is incredibly responsive off idle & power is found at any RPM, in any gear.
What's impressive is that this new turbocharger makes MORE peak HP compared to the now discontinued 58mm SBD500X turbocharger, while spooling up hundreds of RPM faster.
We were so impressed with the response that we installed (2) of these turbochargers on our 4.1L Stroker GTR and headed to the drag strip where we went 8.4 @ 161mph.
The car put down 1135whp on a Mainline Hub Dyno, very impressive for 54mm inducer compressor wheels. (rough 565whp per turbo output)
We updated the turbine wheel aerodynamics as well with a brand new turbine wheel design, which allowed us to reduce wheel size & blade count, increasing spool & reducing backpressure.
All in all, this will be the fastest spooling 500+ whp turbo kit on the market for the FT86 crowd.
The best part of all, we've made this change without raising the price of the turbo kits. They will remain at $2999 complete with TurboSmart Raceport BOV & come with FREE Shipping worldwide!
I can't wait to get some drag strip data on our Subaru BRZ. #ComingSoon
Quick overview of the changes made to our latest turbocharger upgrade for our 2013+ Scion FRS/ Subaru BRZ/ Toyota 86 Turbo Kits!
spdbydesign is offline   Reply With Quote
The Following 4 Users Say Thank You to spdbydesign For This Useful Post:
Calum (01-06-2021), Drifter X (01-06-2021), Irace86.2.0 (01-08-2021), Joe-G (02-08-2021)
Old 01-06-2021, 01:05 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It's awesome to see that you guys are busting ass and still working to stay ahead of the curve while providing an affordable option.
To be blunt though, you'll need to provide some test data from our platform; I know you're working on it, but you'll lose the interest of people by not starting out with the data.
Can't wait to see it regardless
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post:
Calum (01-06-2021), Irace86.2.0 (01-08-2021), sroby (01-07-2021), Trueweltall (01-21-2021)
Old 01-06-2021, 01:09 PM   #3
spdbydesign
I'll have more data to share before the end of the month on the FA20 platform.
Lots of irons in the fire & we had the GTR kits ready to hit the market about 60 days ago, so we had to wrap up testing on that platform first.
The FT86 kits launched yesterday, so we'll spend the next few weeks focusing on this platform
The Following User Says Thank You to spdbydesign For This Useful Post:
DarkPira7e (01-06-2021)
Old 01-06-2021, 03:10 PM   #4
ninjan00dles
Drives: 2015 FRS
I realize it’s not commercially viable or maybe even not possible. But I would love if this kit was CARB legal
I need turbo goodness in my life
ninjan00dles is offline   Reply With Quote
Old 01-06-2021, 03:26 PM   #5
DarkPira7e
DarkPira7e's Avatar
There are 49 other states you could pick Just saying
Old 01-06-2021, 03:31 PM   #6
Calum
That Guy
Drives: 2013 asphalt FRS MT
Is the turbo still based on an 18g or 20g?
Old 01-06-2021, 05:36 PM   #7
spdbydesign
Old 01-06-2021, 05:37 PM   #8
ninjan00dles
Drives: 2015 FRS
Don't remind me
Old 01-06-2021, 05:38 PM   #9
spdbydesign
It is now a ball-bearing CHRA with a 5-axis CNC Point Milled Billet Compressor Wheel
The Following 2 Users Say Thank You to spdbydesign For This Useful Post:
Calum (01-07-2021), sroby (01-07-2021)
Old 01-07-2021, 10:17 AM   #10
spdbydesign
Check out our tig welded SS304L Stainless Steel hard parts from the G500X Turbo Kits, featuring our new 2.0mm thick tubing & dual sided welding!
Irace86.2.0 (01-08-2021), sroby (01-11-2021)
Old 01-07-2021, 11:44 AM   #11
spdbydesign
G500X Turbo Photos!
Old 01-07-2021, 09:57 PM   #12
dpfarr
Drives: BRZ ts
When do stock clutch slip? Noticed the disclaimer to upgrade clutch on the description.
dpfarr is offline   Reply With Quote
Old 01-08-2021, 01:36 AM   #13
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
The stock Exedy clutch is rated for the stock engine’s torque. I have their Stage 1, which is rated at 166wtq. I am running a Harrop kit and an Ace 150 with E85 at a bar of boost, so the clutch is capable of handling a lot more torque. Similarly, the stock clutch can support more. With that said, most supercharger owners tend to upgrade the clutch over 8 psi. If someone is tracking their car then they would typically upgrade with any forced induction. A turbo tends to add more torque than a supercharger, so anything over 5 psi might require an upgrade.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
dpfarr (01-08-2021)
Old 01-08-2021, 01:47 AM   #14
jflogerzi
jflogerzi's Avatar
Any FI I would upgrade your clutch.
2013 Series 10 FRS #553
Coil Bind/Pillow Ball/Spherical Bearing Tein Flex A VOSS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 12-19-2019 08:29 PM
SB18-077 *BRZ ALL, Flywheel assy and ball bearing Trap63 Issues | Warranty | Recalls / TSB 0 05-29-2018 03:26 AM
SBD Announces the SBD500X Ball-Bearing Turbo Kit for the FT86! spdbydesignchris Forced Induction 1 10-20-2016 10:12 AM
FS : Trailer Hitch/Ball mount/Ball/T-connector Sehwan Kim Exterior Parts (Aero, Lighting, Etc.) 3 02-11-2016 01:57 AM
5 spoke TRD wheels 54mm center bore MikeR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-11-2015 12:39 PM
