Old 03-10-2015, 05:34 PM   #1
MikeR
MikeR's Avatar
Drives: 2014 FR-S
5 spoke TRD wheels 54mm center bore
I picked up som TRD wheels meant for Corolla/Matrix. Not knowing anything about center bore, I found out these will not work. The center bore on car is 56mm and have been searching online for and adapter. Anyone have a good source that will adapt from 56mm car center bore to 54mm wheel center bore? I'm pretty sure I need a hub centric adapter but am not finding one the correct size. Any help will be appreciated.
Mike
MikeR is offline   Reply With Quote
Old 03-10-2015, 07:18 PM   #2
swarb
wheels are 54. car is 56. You can't magically make something smaller fit into something bigger.
You either make the hole on the wheels bigger or the outside of the hub smaller. I would take it off the wheels. Machine shop should be able to do it.
Old 03-10-2015, 07:48 PM   #3
MikeR
MikeR's Avatar
Drives: 2014 FR-S
I already tried magic and it didn't work out so well. A machine shop is an option but would rather not modify the wheels which is why I am in search on an adapter...one has to exist somewhere just not finding it in my searches.
Old 03-10-2015, 08:11 PM   #4
swarb
5 choices.
1. open wheel hole bigger
2. grind down hub (not recommended)
3. replace studs AND find an adapter spacer that is hubcentric
4. find a bolt on spacer
5. run 5mm spacer and not care about hubcentric rings which aren't really necessary. Measure the hub depth to make sure.
I'd go for #5.
Old 03-11-2015, 12:39 PM   #5
MikeR
MikeR's Avatar
Drives: 2014 FR-S
I will give that a shot tonight, thanks for the info.
Center Bore MooKz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 03-09-2015 03:56 PM
Concerns on dual bore sizing of wheels? Barry Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-15-2014 02:02 PM
08 sti five spoke wheels on brz subyboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 12-17-2013 07:29 PM
What Bore do we need on wheels? SillySaxon Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-03-2013 01:14 PM
FS: SoCal TRD 5 Spoke wheels peenut1086 Wheels and Tires 0 11-07-2012 11:26 PM
