Old 12-17-2019, 12:46 AM   #1
VOSS
Drives: --
Coil Bind/Pillow Ball/Spherical Bearing Tein Flex A
Ill try to be brief. Sound is starting to drive me nuts.
I hear a creaking noise whenever I turn the steering wheel. It only occurs when either going really slow or at a standstill. Dont hear anything at speed. Sounds like the video below but not nearly as bad.
[ame="https://www.youtube.com/watch?v=h3jLmpI-XAM"]Coilover Spring Binding - YouTube[/ame]
Shop told me the spherical bearing in my front right coilover is seizing. Best way to fix is replace. They sprayed some lubricant on the top of the coilover which seemed to help a bit but a week later its back.
Emailed Tein and they're refusing to send parts under warranty. Car has never been tracked, coilover usage is under 13k miles, and it's been 9 months since install. They're stating it MUST be sent to them because there is a "special tool" they use to remove the bearing from the mount. They're claiming I also have to pay for it because its wear and tear.
Anyone replace the spherical bearing on a Tein Flex A? I saw others mention the radial bearing from Fortune Auto but dont know if its the same for the Teins. Any suggestions?
PS, this is my first coilover but seems like bullshit to me that 9 months in its falling apart. I get wear and tear, but a coilover under 13k miles and under a year since install is ridiculous to me. I get they're not top of the line but I'm not tracking my car. Maybe you can tell me if I'm being unreasonable.
Thanks
VOSS is offline   Reply With Quote
Old 12-17-2019, 01:18 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
First try tighten top nut maybe. Imho this vid might be helpful. Though also possible that bearing is already too worn (untightened simply propagates wear due play in it) and yes, needing replacement.
Old 12-17-2019, 01:24 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'd ask the shop how they came to the conclusion that it is seizing.
I'd also jack the car up and grab the spring and see if it rattles. The preload collar on my flex Z's would work loose and the spring would come loose. This would make it pop.
Old 12-18-2019, 09:12 PM   #4
Contender
Drives: 2017 Toyota 86
Please let us know if you fixed it I was about to order a set but now.. I am not sure I want to fuck with the ride.
Contender is offline   Reply With Quote
Old 12-19-2019, 08:17 AM   #5
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Thanks
It's 99% because of where you live, not necessarily the quality of the component, per se... You're in the snow belt, which means you're in the salt/sand/rust belt. Aftermarket stuff NEVER gets tested to the degree that OEM parts do for corrosion resistance, and this is the effect of using a brand that's on the lower end of the spectrum (TEIN can afford to be inexpensive not only because of the quality of components they use, but also their relative lack of service/support, which you're experiencing...repairs cost money), plus living in probably one of the worst locations on Earth for corrosion. I'm in New England, so I have the same problem; I've already had to replace my OEM strut bearings once and I'm only at ~65K miles. If you lived in SoCal or Arizona, you'd likely still be noise free...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 12-19-2019, 04:38 PM   #6
Spherical bearings can't be lubricated with a spray; they use solid dry lubricant.
If that spherical wasn't damaged before, your shop damaged it by spraying lubricant, and eliminated any possibility of warranty. It most likely wasnt damaged before, but is compromised now.
That spring bind can be fixed with a fresh teflon washer/spacer, similar to the one that came with your coilover kit. The teflon is wear and tear, and wears out much quicker in Canadian conditions. You could use bearing based thrust washers instead, but those would wear out much faster.
The washer is $6 each. Shipping it to you will cost more than the part. PM me if you want it.
Old 12-19-2019, 05:40 PM   #7
HaXx
Drives: jrsc_brz
thread jacking a little here: how can this be prevented? i just got slightly used FA 500w/ swift springs. 5kmiles. is there anything easy i can do to "freshen up" before they go in? theyre in great shape, but i was thinking maybe dry lube the pillow ball in the camber plates maybe? there is a *touch* of surface rust, but the pillowballs are buttery smooth. link to the coils i got:http://www.ft86club.com/forums/showthread.php?t=138027 btw, ordered all my filters to freshen up the jrsc from csg last year
HaXx is offline   Reply With Quote
Old 12-19-2019, 06:26 PM   #8
venturaII
venturaII's Avatar
Actually there are plenty of spherical bearing types that are greaseable, though all the ones I've seen have been either two or three piece metal-on-metal. If the OPs is a 3 piece with a PTFE race, then hitting it with generic spray lube will almost certainly cause accelerated degradation.
Old 12-19-2019, 07:43 PM   #9
They're wear and tear items; nothing you can do to refresh sphericals really.
If the tops are articulating smooth without play, I'd say just run them as is and you'll be just fine.
Old 12-19-2019, 08:29 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have been lubing my Flex Z's with spray white lithium grease for two years. No issues. That is not to say that in the future the lining won't be degraded, but so far so good.
Tein Flex Z coil overs - SOLD JohnnieBoy Brakes, Suspension, Chassis 4 11-20-2018 03:10 PM
D1 Spec Coil-Overs w/ Pillow Ball Mount (Toronto) Sweet48 Canada Classifieds 7 11-18-2017 11:32 PM
Help needed with KW V3 coil overs and RSR pillow ball top mounts RevoG Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 09-29-2015 09:17 AM
FS (GA) Tein Street Flex Coilover Adjustable w/ pillow ball mounts GTHachiRoku Brakes, Suspension, Chassis 11 09-28-2014 10:09 PM
Tein flex pillow top coilovers Frs89 Brakes, Suspension, Chassis 1 06-15-2014 06:37 PM
