Old 10-20-2016, 10:02 AM   #1
spdbydesignchris
spdbydesignchris's Avatar
Drives: 2013 BRZ Premium
SBD Announces the SBD500X Ball-Bearing Turbo Kit for the FT86!
SBD announces the launch of our $2999 "Stage 2" SBD500X Turbo Kit, which features our 58mm Inducer Ball-Bearing Turbocharger for even more power
*Custom Ball-Bearing 58mm Inducer Billet Compressor Wheel CHRA
*Ball-Bearing, Oil & Water Cooled
*Internally Wastegated with 0.7 Bar (10 PSI) Spring
*58mm IND/76mm EXD Compressor Wheel
*60mm IND/55mm EXD Turbine Wheel
*Power levels up to 300-325whp are Capable with a Stock Motor + 91/93 Octane Gasoline
*Power levels up to 400whp are Capable with a Stock Motor + E85 Ethanol
*Power levels up to 500whp are Capable with a Built Motor + E85 Ethanol
The turbocharger is a 100% Direct Swap Plug-N-Play that re-uses your existing SBD400X Oil Feed & Return Lines. It re-uses the same compressor cover found in the SBD400X kit, machined for the larger 58mm compressor wheel, so your inlet piping & filter are identical.
Simply add the two water lines for an easy and fast installation.
https://spdbydesign.com/product/sbd5...-brzscion-frs/
Available as a complete turbo kit for $2999 or as a standalone turbo upgrade to the SBD400X turbo kit for $1099!
400whp on E85 @ 14 PSI on a 100% Stock Internal Engine (Uncorrected, Actual DynoJet Measurement!)
spdbydesignchris is offline   Reply With Quote
Old 10-20-2016, 10:12 AM   #2
spdbydesignchris
Got to love that flat torque curve
Good job EQ Tuning in Northern California on this car!
Just another 450whp Turbo FT86 -- and NOW 530hp VitViper Forced Induction 303 12-14-2017 10:44 PM
990 Owner's and counting, the SBD FT86 Turbo Kit! spdbydesign Forced Induction 0 04-24-2016 12:35 PM
FS : Trailer Hitch/Ball mount/Ball/T-connector Sehwan Kim Exterior Parts (Aero, Lighting, Etc.) 3 02-11-2016 01:57 AM
Release Bearing or Pilot Bearing Cal3000 Engine, Exhaust, Transmission 11 01-27-2015 10:39 PM
ft86 turbo RWD or AWD? CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 31 01-18-2010 04:11 AM
