Old 10-07-2015, 06:02 PM   #15
BarryPanick
BarryPanick's Avatar
Drives: 2015 Subaru BRZ Limited
Originally Posted by FullBlown View Post
It is in the tune Barry, I am still waiting for that tune file from your tuner.....
They gave me my car back and said everything was fine.... I should have called you first but I was so busy and needed my car back... I need a reliable performance shop around south jersey...
BarryPanick is offline   Reply With Quote
Old 10-07-2015, 06:12 PM   #16
BarryPanick
Shoot me an email please so I can have a direct way of contacting you.
I just texted the co owner the shop I go to..
I said this, " Full blown says they are still waiting for the tune from you guys.. And my car had 2 rough start ups today.. Full blown keeps insisting its with the tune, along with several other people. "
He responded, Roshan spoke to LJ on the phone. Tell them to send a tune over for it. It should come with a base map when you buy the kit. roshan@powerhaus-performance.com
... Man I really just wanna drive my car without worrying.
Old 05-28-2018, 09:42 PM   #17
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Any update on this (years later)? I am having the same issue with my new setup - Injector Dynamics 1050x and E85. Will start fine cold, but not hot. Will just crank for days. Flooring it doesn't seem to help. Leave it alone, come back later, and it starts.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 01-05-2021, 11:29 PM   #18
RG4L
Im having the same problem... I have the FB kit woth 1000cc injectors and ecutek tune from Zach Tucker and my car does great on cold starts but once it gets warm it wont turn back on... at all not even by pressing the gas and its irritating... If anyone finds a fix let us know...
RG4L is offline   Reply With Quote
Old 01-06-2021, 02:41 AM   #19
tomm.brz
Drives: brz 2017 hksv2
well it s a tune problem, you won t fix it magically just by sitting in there
you neeed to ask zach to handle it since it s the only one able to enter your current tune
Old 01-06-2021, 05:52 AM   #20
RG4L
I did, he's tried multiple things and still nothing. We even took a log while cranking the car while warm ans still he couldn't find anything bad on the tune..
Old 01-06-2021, 08:20 AM   #21
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
How do the wires look on the cam sensor close to the downpipe? I found that mine had been melted (I had other issues, but this wasn't helping). I bought DEI cable sleeving for the the plug and wiring, since they sit close to the downpipe.
Old 01-18-2021, 07:03 PM   #22
yakizoba
Drives: 2012 Toyota 86
I also have this problem, but found myself a workaround for this issue.
When your car bogged down after first hot-crank:
- Try pulling fuel pump fuse out ("F/PMP" on engine bay fuse box, 20A yellow fuse)
- Then try start the engine up again.
- If it successfully cranks, don't forget to put the fuse back in before the fuel rail drys out.
FYI: my car have ID1050x, DW300c pump, TD05H-20G turbo, EcuTek, flex-fuel, normally runs E73.
I don't have the opportunity to working with my tuner yet because of the COVID-19 lock-down state in Thailand.
Good luck.
yakizoba is offline   Reply With Quote
Car won't start! Making weird sounds. B_Rad Issues | Warranty | Recalls / TSB 35 01-25-2017 05:33 PM
No crank no start issue *KID* Issues | Warranty | Recalls / TSB 3 09-29-2014 06:22 AM
Weird issue with oft not reading cel fenton Software Tuning 7 09-14-2014 12:26 PM
weird issue at high speeds after OFT tune dejxx Software Tuning 24 08-10-2014 09:49 PM
weird issue after BPB & OFT install DAN_BRZ Engine, Exhaust, Transmission 10 06-10-2014 09:53 PM
