Old 12-11-2020, 08:49 PM   #29
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by ZDan View Post
This sounds very similar to what I experienced. Insane asymmetric front lockups at brake pedal forces way below what should produce that even without ABS. Initial diagnosis with normal OBD-II reader diag was steering angle sensor but deep dive with laptop and diagnostic software showed "yaw sensor error".
Interesting. My code reader displays the yaw sensor output live and it seemed ok (although sebring people weren't happy with my testing i bet). Steering angle showed -25 degrees when straight so that helped with the code error pointing to a specific issue. Helped by the fact i threw this clockspring in after it failed on srs testing in another car. I'm going to watch it tomorrow and if its annoying I'm pulling the fuse. Right now im just treating it like a time trial and doing 4 laps then coming in and restarting and doing 4 more ha
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
CSG Mike (12-13-2020)
Old 12-11-2020, 08:56 PM   #30
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Pat View Post
Wow, that is a HUGE difference. Impressive.
Full disclosure the alignment is also a bit more aggressive which will make up some of that improvement. The biggest difference is how the SRCs are handling the rough ass sebring surface. These bounce, a lot, but they don't violently toss the car a foot sideways like the eibachs did. T17 here is a lot better with the SRCs. My corner speeds in t10 and t13 are also multiple mph faster but most of the corner speeds seem similar. The SRCs are pushing more even with more toe out up front. Trying to adjust with tire pressure for that.
End of the day though, they are faster.
Oh also im using them with teins edfc active pro setup that ive now spent a bit of time fine tuning..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 4 Users Say Thank You to Dave-ROR For This Useful Post:
bcj (12-12-2020), CSG Mike (12-13-2020), Pat (12-12-2020), soundman98 (12-11-2020)
Old 12-11-2020, 10:31 PM   #31
Dave, do you pedal dance?
Old 12-12-2020, 07:27 AM   #32
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Tracbox to do so, but yes.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-12-2020, 01:04 PM   #33
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yeah, sounds like clockspring... My steering angle was reading normally when we checked it in the garage. If you have same pads front/rear probably better off to just yank the fuse. Crazily asymmetrically locking front brakes bad!
Old 12-12-2020, 01:09 PM   #34
I ask because I get where Mike was coming from. Unless I'm missing some key part of the system, this has nothing to do with the yaw gyro or steering wheel sensor. Do you or @Opie have any spare ABS units to swap in for testing?
Old 12-12-2020, 01:59 PM   #35
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I doubt it, we never need them so they go to the scrap yard. I need to fix pad bias now ha
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
CSG Mike (12-13-2020), Ultramaroon (12-12-2020)
Old 12-12-2020, 03:44 PM   #36
Oh, because abs fuse?
Old 12-12-2020, 05:42 PM   #37
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yeah.. not the fronts lock earlier because of the pad.. running ds1.11 up front and only ds2500 in the back.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-13-2020, 01:27 PM   #38
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
If I was in town (instead of at MSR Houston with the Austin86 & Houston86 groups) I would use the techstream to recalibrate the steering angle sensor and see if that improved anything. Definitely sounds TCS related. My car was hyperactive on track at one point last year because mine hadn't been recalibrated.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 12-13-2020, 02:13 PM   #39
Were you also in PD mode? (full vsc disable, test mode, whatever we're calling it)
Old 12-14-2020, 06:07 AM   #40
Opie
Opie's Avatar
Yep
Old 12-14-2020, 10:03 AM   #41
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Oh yeah.. to reconfirm that the left front is the worst.. the LF tire is flat spotted almost to the cords.. the front right is just slightly flat spotted. I ended up just switching the left front and the vibration from the flat spot went away about 98%...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-14-2020, 12:31 PM   #42
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Video of when it happened...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Ultramaroon (12-14-2020)
door ajar warning light Cobaltbloo Scion FR-S / Toyota 86 GT86 General Forum 8 01-12-2020 06:04 PM
Warning Light? albeezy Issues | Warranty | Recalls / TSB 49 12-22-2016 08:01 PM
my warning egine light is on vinpan Issues | Warranty | Recalls / TSB 10 05-07-2013 11:44 PM
TPMS warning light FRSowner Scion FR-S / Toyota 86 GT86 General Forum 6 12-30-2012 08:24 PM
Warning light came on, what could it be? whtchocla7e Issues | Warranty | Recalls / TSB 13 10-21-2012 04:20 PM
