Old 11-23-2020, 01:09 PM   #1
Sniepster
Drives: 2013 Toyota 86
Possible oil leak?
So ever since I got my car (2-3 weeks) it had this seemingly oil leak on the front of the engine near the front crank seal extending leftmost on the passenger side. I had the car inspected and it was confirmed the oil looks old. I've checked the oil frequently and it does not seem like it is burning or leaking. Is the front crank seal an issue with these engines? I'm also attaching some pics for opinions. Will be trying to clean it up to see if the seepage is current or was addressed. The previous owner took really good care of the car and changed the oil much more often than the recommended schedule, he also assured me the engine does not leak nor burn oil.
Pics:
https://ibb.co/Gx88wkz
https://ibb.co/pbs6cLG
Sniepster is offline   Reply With Quote
Old 11-23-2020, 01:53 PM   #2
Gloonge
Drives: 2013 frs raven
Kinda looks like it's seeping from the dipstick tube oring and being blown around by the fans.
Gloonge is offline   Reply With Quote
The Following User Says Thank You to Gloonge For This Useful Post:
whataboutbob (11-23-2020)
Old 11-23-2020, 02:13 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
There are lots of places it could be leaking from. I would clean it off for now and check those areas again later to see if you getting more buildup. It is not too uncommon to get a little seepage from the dipstick oring. The AVCS solenoids have orings that will leak as well. The timing cover and valve cover are known to leak sometimes, those are both a pain to fix. Front main seal is not a common one.
humfrz (11-24-2020)
Old 11-23-2020, 03:34 PM   #4
ls1ac
ls1ac's Avatar
Early rust prevention technology
The Following 5 Users Say Thank You to ls1ac For This Useful Post:
DarkPira7e (11-23-2020), Jdmjunkie (11-23-2020), NoHaveMSG (11-23-2020), soundman98 (11-24-2020), Ultramaroon (11-24-2020)
Old 11-23-2020, 05:44 PM   #5
Grady
Grady's Avatar
If it is not dripping on the floor it is not a leak. An engine can seep oil. If you would clean your engine once in a while problem gone.
Old 11-23-2020, 06:50 PM   #6
whataboutbob
AutoX-10/10ths every run
^this
I had this seal go bad on mine. Similar accumulation of residue.
Build thread:Here
Old 11-23-2020, 07:47 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My OG engine looked like that It was the driver side exhaust AVCS solenoid oring.
Old 11-24-2020, 12:45 AM   #8
I wouldn't mess with it or worry about it.
Eat turkey and be happy!
Old 11-24-2020, 02:15 AM   #9
Sniepster
Well thanks everybody for the answers. Haven't gotten around to it but will be cleaning the area as best as i can and then keen an eye out if the seepage continues and where it's coming from.
Old 11-24-2020, 06:10 AM   #10
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
That's not a leak, that's a seepage.
It looks like the dipstick o ring, but if components aren't wet there is little cause for intervention. Clean it off with engine cleaner and forget about it.
Old 11-25-2020, 02:37 PM   #11
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
Like other members said, I would so a full engine bay cleaning with degreaser and monitor the possible issue, which is likely not an issue.
SUSPECT_BRZ is offline   Reply With Quote
Gas Leak? Fuco Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 10-07-2022 09:40 AM
Oil leak help please TorontoNat Engine, Exhaust, Transmission 7 12-27-2018 11:02 AM
Oil Leak Adamf220 Issues | Warranty | Recalls / TSB 11 05-04-2018 02:51 PM
Oil Leak Brz_racer Engine, Exhaust, Transmission 22 07-17-2017 04:28 PM
Help - oil leak tlim Engine, Exhaust, Transmission 4 04-10-2015 08:40 AM
