Old 12-26-2018, 01:29 PM   #1
TorontoNat
Drives: 2013 Scion FR-S Asphalt [Gray]
Oil leak help please
The car runs fine, doesn’t overheat but the smell is pretty bad after long ish drives and there is obviously oil there but not sure at all where it could be coming from. The level seems to not move but I am definitely burning oil when I’m driving. Here is a picture, Any help is greatly appreciated, thanks guys, merry Xmas!
"Enjoying Performance because of it's nature not because of it's quantity''
TorontoNat is offline   Reply With Quote
Old 12-26-2018, 01:33 PM   #2
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
If you're in front of the engine look down the right side of the engine. There is a common leakage toward the bottom.
Someone back me up, what is the part that leaks. Cam cover? I forget.
Check that section of the engine for oil sludge. You could also check the oil return plate (used if auto, but manual covers it with a plate). If you need specifics let me know I'll find the names of the parts or get you some pics.
Sent from my ONEPLUS A6013 using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 12-26-2018, 01:38 PM   #3
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Timing cover yep. He posted in another thread right after this with his picture.
MCTeeJ is offline   Reply With Quote
Old 12-26-2018, 09:04 PM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Old 12-26-2018, 09:09 PM   #5
Strife26
Strife26's Avatar
Right above the headers, no wonder it's burning it.
Old 12-26-2018, 10:02 PM   #6
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Isn't there a TSB for the seal being crap work. I'm pretty sure that's the cause. (I have the same issue but I'm waiting for the recall to take care of it since it's going to pull off the cover anyways - I assume)
Old 12-27-2018, 10:08 AM   #7
TorontoNat
@Strife26
@MCTeeJ
Thanks guys, good to know it's not as bad as it smells haha. Will get a chance to lift it and take a look under the engine today to take a better look! Will post developments.
Cheers!
Old 12-27-2018, 11:02 AM   #8
MCTeeJ
MCTeeJ's Avatar
Originally Posted by TorontoNat View Post
@Strife26
@MCTeeJ
Cheers!
Yeah it's more because it's above the header and burning off. A lot of people have the same leak on the driver's side but since it doesn't burn it just drips onto the pan and mixes with dirt lol.
Gas Leak? Fuco Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 10-07-2022 09:40 AM
Oil Leak Brz_racer Engine, Exhaust, Transmission 22 07-17-2017 04:28 PM
Oil Leak? Tofu-86 Forced Induction 3 09-23-2016 03:47 AM
Oil leak GsxrMe Forced Induction 4 12-18-2015 08:23 PM
Oil leak. ohnoitsthefuzz Issues | Warranty | Recalls / TSB 2 03-23-2015 01:31 AM
