Drives: 2016 Scion FRS
Car getting stuck in gear / not going into gear
Hello guys,
I have been having the issue of my car refusing to get into gear or when it does get into gear, it doesnt want to come out of that gear. This issue only happens when the car is fully stopped. Things i have done to try to fix this issue: - bled the clutch system - adjusted the clutch pedal - adjusted the reverse lock bracket- - changed the transmission fluid - changed to a brand new aftermarket clutch - changed my clutch fork Car drove fine for 2 weeks but yesterday i went for a super long drive and it came back. Let me know your thoughts. Thanks 🙏. |
#2 |
Famous Potatoes
Drives: '15 ultramarine
What clutch?
#3 |
#4 | |
The Dictater
Drives: '13 Red Scion FRS
1. Car drove fine 2. Car stopped letting you shift out of the blue. 3. Then you did all that troubleshooting. (Did you do it all at once or tried one at a time?) 4. Car drove fine for 2 weeks until you went for a long drive. 5. The issue came back exactly as before. 6. You posted here. Please let us know if that is incorrect or if there are before/after/between parts of the story I missed. Also, are there any abnormal noises? |
#5 |
Maybe your clutch cylinder or slave cylinder is bad?
#6 | |
| The Following User Says Thank You to hamish.frs For This Useful Post: | Spuds (10-05-2020) |
#7 |
Next thing im going to swap is the clutch cylinder for sure. But i posted here to see if theres anything else there could be. My car is still fairly new it only has 20,000 miles so it would be weird if my cylinders were giving out so early.
| The Following User Says Thank You to hamish.frs For This Useful Post: | humfrz (10-05-2020) |
#8 | |
Back in the day, we NEVER had ANY problems with clutch cylinders. This is a test to see iffen you're payen attention - know why didn't we have any problems??????????? I hope you get it sorted out. |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (10-05-2020) |
#9 |
Stock flywheel? Have you checked it's surface?
#10 |
The Dictater
Hmmm... Any chance the transmission is misaligned with the shifter? I know it's a pretty direct connection, so not much to go wrong there. Maybe just a bad transmission mount or something?
Hypothesis is that when you replaced the clutch you realigned everything correctly, but then something in your longer drive caused it to shift out of alignment. ... It does seem like a classic clutch problem though. If you are in gear with the car off and start the car with the clutch pedal pressed, does it still start? |
#11 |
Drives: Crapcan
Stock clutch fork?
#13 | |
#14 |
| Gear indicator not registering 5 th gear on 6mt | sroby | Engine, Exhaust, Transmission | 20 | 03-18-2020 11:43 PM |
| AT - 1st gear gets stuck and hits high RPM's before shifting | undone14 | Issues | Warranty | Recalls / TSB | 7 | 05-27-2018 11:23 PM |
| 1st & 2nd gear stuck? | YoungChow | Issues | Warranty | Recalls / TSB | 11 | 07-24-2017 12:11 AM |
| Gear indicator (G-on) shows 2 when in 3rd gear | c8Face | BRZ First-Gen (2012+) — General Topics | 31 | 07-07-2017 07:23 PM |
| Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl | jakebrz | Issues | Warranty | Recalls / TSB | 14 | 06-06-2016 06:28 PM |
