Old 08-25-2020, 04:29 PM   #1
COBlue
COBlue's Avatar
Drives: 2017 Subaru BRZ Limited PP
Brake flush and ABS
Does anybody use OBD computer to pump ABS to completely flush fluid out of the system? Is it even necessary on our cars? (Friend with a Corvette mentioned it and can't find any info on the twins.)
COBlue is offline   Reply With Quote
Old 08-25-2020, 08:32 PM   #2
Did your friend also suggest you get some blinker fluid at the auto store when you buy new brake fluid?
(jest ah messen wich ya - )
COBlue (08-25-2020)
Old 08-25-2020, 09:49 PM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
I've never done it. I usually flush every 2nd or 3rd track events, never any issues.
COBlue (08-25-2020)
Old 08-26-2020, 12:16 AM   #4
Jdmjunkie
Drives: Scion FR-S 10 Series
If you are worried about air in the abs pump the old school way of doing it is to take the car onto a slick surface like a wet, icy, or dirt road. Then activate abs repeatedly and it will bleed itself eventually.
Jdmjunkie is offline   Reply With Quote
Old 08-26-2020, 12:37 AM   #5
COBlue
COBlue's Avatar
Might do that just to be sure, but allegedly the goal is getting as much old fluid/moisture out as possible.
Old 08-26-2020, 01:55 PM   #6
Grady
Grady's Avatar
If you are doing brake fluid changes regularly, done worry about it. If you brake fluid has not been changed for 10 years and you are going to a track day tomorrow it may help.
Can I get this flush? BRZBYE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-24-2016 07:26 AM
Brake Fluid Flush protpibe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 01-02-2014 03:19 PM
Brake fluid flush - need some help THEWAKLER Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-06-2013 11:13 PM
Brake flush question... N_I_N Tracking / Autocross / HPDE / Drifting 18 06-09-2013 08:13 PM
Flush +/- DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 08-13-2012 12:37 PM
