Old 07-24-2020, 07:59 PM   #1
airrick
Drives: TRD R.S. 1.0 FRS
Oem front pipe flange rust
I noticed there was a leak on my front pipe. Already tried new gaskets, i was already thinking about replacing the oem front pipe since i am now boosted with Works turbo stage 2. Was going to get a 2.5 FP to get the exhaust to flow a bit better. But its now a sped up timeline.
Is JDL ultra quiet worth the price? I was going to get a HKS dual resonated front pipe but its only a 60mm(2.3in) pipe diameter. 2.5 quiet front pipe. Any ideas?
airrick is offline   Reply With Quote
Old 07-25-2020, 04:14 PM   #2
I wouldn't worry about the rust on that flange.
about your other questions.
airrick (07-25-2020)
Old 07-25-2020, 07:01 PM   #3
ls1ac
ls1ac's Avatar
That car is way too clean, need to go drive in the mud.
That is surface rust and is normal.
Put some exhaust gasket compound on the hard gasket, Follow instructions on finger tighten then wait whatever hours then torque.
The Following User Says Thank You to ls1ac For This Useful Post:
Old 07-25-2020, 08:07 PM   #4
airrick
Haha yea iono about driving in the mud. Car is lowered. I have never used exhaust rtv/compound. My main concern the leaking since i know my turbo application is gonna run a little rich.
Ill pick some up and report back with results.
Old 07-26-2020, 03:37 PM   #5
airrick
No dice.
Put some rtv copper compound. Seems like it leaks more. I dont know either its the gasket or the flange. I already have replace the gasket once.
Im thinking i should just get a 2.5 front pipe to match my downpipe.
Old 07-26-2020, 04:06 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Why not bring it somewhere that has a belt sander and ask them to flatten the flange? I'd hardly call that rust (not to belittle the issue you're facing) so unless you're itching for a reason to upgrade, I wouldn't bother
airrick (07-26-2020)
Old 07-26-2020, 05:23 PM   #7
airrick
Yea, I understand i could just fix my flange. But since being boosted with a turbo, my downpipe is 2.5 inches and TRD quad tip catback is 2.5 inches. The front pipe and midpipe are tiny. It feels like its choking the turbo a little. Im thinking about getting my local muffler shop to see if i could just get a custom setup since theres no aftermarket 2.5 midpipe that fits my Trd quad exhaust. Its that itch too.
But ill still ask them to flatten my flange thanks for the suggestion!
The Following User Says Thank You to airrick For This Useful Post:
DarkPira7e (07-26-2020)
Old 07-26-2020, 06:43 PM   #8
DarkPira7e
DarkPira7e's Avatar
Totally missed that you're turbo. The backpressure maybe is what's blowing that seal, I definitely support opening the exhaust then!
Old 07-26-2020, 06:49 PM   #9
airrick
Yea, the grey pipe is the downpipe. You got any ideas for good quiet 2.5 FP? i only really see the JDL Ultra quiet one.
Old 07-26-2020, 07:11 PM   #10
DarkPira7e
DarkPira7e's Avatar
Literally just bought the ultra quiet front pipe to see if it's better than the straight 3" frontpipe I had made before on my turbo setup. Seems like it'll be perfect
Old 07-26-2020, 07:48 PM   #11
ls1ac
ls1ac's Avatar
The only time water can sit on an exhaust pipe is before the engine has warmed up.
I do not see an indication of the normal black gas escaping from the pipe. Do you hear the lisp of escaping gas when you are warmed up?
Old 07-26-2020, 08:20 PM   #12
airrick
Blah if only it didnt cost so much. dangit.
hmm, i see. Honestly, i can't tell. my car is kinda loud already. seems like what @DarkPira7e has said about the backpressure may be correct. i can see water/gass splatter on the top of the frame. so im assuming its somehow coming from the top of the flange.
Car was on for maybe for about 2-3 minutes at this point.
Old 07-26-2020, 08:33 PM   #13
DarkPira7e
DarkPira7e's Avatar
https://www.ft86club.com/forums/showthread.php?t=141612
$500!
Old 07-26-2020, 08:49 PM   #14
airrick
thanks but my turbo setup doesnt use an overpipe. and its actually cheaper to buy it new. like $450 or so for my 2.5 one. just gotta wait like 2 weeks for them to make it bleh.
LF: OEM Front Pipe (very low km, minimal rust) sergiomordo Canada Classifieds 0 06-23-2020 05:55 PM
AFE Takeda Intake, Perrin OP, Injen Test Mid pipe, 2.5" to 3' exhaust flange Ignore Your Doctor Engine, Exhaust, Bolt-Ons 7 05-29-2020 10:20 PM
no flange for donut gasket on J2 front pipe k0tkmnd Engine, Exhaust, Transmission 1 06-05-2015 02:04 PM
Front pipe flange warped? Fizz Engine, Exhaust, Transmission 3 12-23-2014 02:47 PM
Borla UEL flange, more in common with a pretzel then a flange. Adeets Engine, Exhaust, Transmission 13 04-12-2013 05:38 PM
