Old 07-15-2020, 08:17 PM   #43
86TOYO2k17
Drives: 2017 toyota 86
I don’t seem to have an issue with that NA There were about 10 in my run group Saturday and I had to give zero point byes. I’d also be curious how FI would handle 5psi at over 4K rpm.
Lol, I was just joking around with your wording.
Plus year, mileage, and model of Porsche make a big difference.
5psi would do beautiful things. 10 would do even more.
Old 07-15-2020, 08:27 PM   #44
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
lol yeah, and using track days is a terrible reference since most people just get enjoyment from getting to drive the cars they own on track, not from trying to set a lap. Most were newer models though, probably worth more then the last rental house of mine I am trying to remodel and sell. Eating into my K swap budget.
Too bad that number is oil pressure
Old 07-16-2020, 12:23 PM   #45
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by DarkPira7e View Post
This is my chief sentiment. As I've said in older threads, I was stuck in the 80s/90s for a long time. I owned a couple NA Miatas and a few E36s. I'd get something newer with more power, and come back to the basic platforms.
You can't make a WRX a lightweight coupe RWD corner rocket, you can't take the laziness out of an e46, you can't add a little room to your NA Miata, and you can't stop your e36 from losing its window regulators.
For $5,000 more than you buy the car for, , you can have 270whp on a totally stock car with ECUtek that handles amazing, has 6 gears, a limited slip differential, and the most common bolt pattern in the world.
No other car I've seen matches my needs so well, it's crazy. I just wish it had an inline 4 instead of a shitty boxer engine
I love that little shitty boxer. Absolutely love it.
It gives me the same mpg as a Corolla when driven like one. It makes my car as fast as a Cayman when driven as one.
Old 07-16-2020, 12:44 PM   #46
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Nothing inherently wrong with it I'm just not a fan. I like having my plugs and oil leaks up top
Old 07-16-2020, 12:57 PM   #47
mrg666
pessimistic skeptic
mrg666's Avatar
I like Mazda Skyactive G engines though. I wish Miata had a bit more space inside.
SOLD- Invidia EL-Header, Over-Pipe, Front-Pipe, Q300 Exhaust AW0802 Engine, Exhaust, Bolt-Ons 9 11-02-2017 03:18 PM
Front pipe recommendation to prevent rasp magicallydelicious Engine, Exhaust, Transmission 4 08-04-2016 09:43 PM
Ceramic coating header only vs header/over pipe/front pipe pixel67 Forced Induction 8 08-18-2015 02:39 PM
Crossover/mid pipe Recommendation Toyota John Engine, Exhaust, Transmission 7 06-09-2014 12:40 AM
