Old 08-04-2016, 08:30 PM   #1
magicallydelicious
Drives: stock
Front pipe recommendation to prevent rasp
I'm collecting the exhaust parts to install all at once. I have tomei uel, perrin 2.5 over pipe, and 2.5 perrin non resonated catback. I'm not sure if it will be raspy as is, but I want to ensure it won't be. Anyone have this setup, and if so, what front pipe do you use, and is there any rasp?
magicallydelicious is offline   Reply With Quote
Old 08-04-2016, 08:39 PM   #2
ButeraFRS
Guest
Posts: n/a
I don't have that exact same setup but you already removed your resonator on the midpipe, so you might have some rasp regardless.
Either way, if you want to reduce rasp get a resonated front pipe
Sent from my SM-G530W using Tapatalk
Old 08-04-2016, 08:43 PM   #3
magicallydelicious
Drives: stock
That was my fear. I may email Perrin and ask about potentially trading the midpipe, the system is brand new still.
Old 08-04-2016, 09:30 PM   #4
ButeraFRS
Guest
Posts: n/a
The midpipe helps a lot. For reference I'm running a test muffler and front pipe with a stock header and midpipe and honestly it is just on the verge of rasp. That midpipe helps so much. But since you're running (I'm assiming) a cat less header, youd probably want to keep as many resos as you can
Old 08-04-2016, 09:43 PM   #5
kch
Senior Misanthrope
kch's Avatar
Two more options: the HKS dual-resonated FP will reduce rasp significantly. there's also the JDL "Ultra-quiet" FP. Name is a bit misleading as it's not really quiet; it just has a cat + resonator. That's what I use.
Catback to reduce rasp from HFC Front Pipe? Sh1FTy Engine, Exhaust, Transmission 2 06-24-2016 01:17 PM
WTT Invidia catless front pipe for a resonated/catted front pipe nickmerronesucks Want-To-Buy Requests 3 05-10-2016 02:25 PM
Catless Front Pipe VS Test Front Pipe. What's the Difference? geruta Engine, Exhaust, Transmission 48 04-23-2015 04:07 PM
Crossover/mid pipe Recommendation Toyota John Engine, Exhaust, Transmission 7 06-09-2014 12:40 AM
Gains from aftermarket catted front pipe vs stock front pipe? Vmax911 Engine, Exhaust, Transmission 4 01-20-2014 01:42 PM
