Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Crossover/mid pipe Recommendation
I am looking to get some recommendation for a catless crossover/mid pipe in combo with my EL catless header i have. I am looking to get the quietest best flowing exhaust combo I can find. I have an Agency catless header, Agency mid pipe and greddy evo 3 exhaust and its way to loud. I was hoping to keep the greddy cat back and replace the crossover mid pipe to keep the noise down but if i have to replace both I will.
Off Topic
"Catless" and "quiet" are mutually exclusive.
If you want a quieter exhaust, get a front pipe that has a high flow cat and a resonator. Nameless makes one, Magnaflow makes one, there are a few more that I can't think of at the moment. Then get a quiet cat back with a resonator such as the resonated Perrin or the Invidia Q300. |
#3 | |
Drives: '13 Ultramarine FR-S M/T
if you want less volume get a catted front pipe and change the cat back to something quieter. A single muffler CBE is usually the way to go for quieter. my vote is nameless combo pipe but you have to jack the engine to get it in.
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's |
Calle Atun
Maybe I am calling the parts by the wrong namw. I have a full exhaust. Agency EL header, Agency crossover and forward pipe that connects to the Greddy evo 3 cat back. I put the stock catback back on for now because it was way to loud. I was thinking the Greddy SP because I like the tips and people are complaining its too quite but I don't like how is uses the stock rear cat back pipe with the sp muffer. But the Crossover and front pipe have so many different companies making them, I don't know where to start. If anyone is running a catless header, what is the rest of the exhaust parts you are using and a youtube clip would be nice too.
Off Topic
The crossover pipe is just an overpipe, and the forward pipe is the front pipe. The front pipe has a cat and a resonator; the overpipe is just a pipe.
So you're basically running a straight front pipe, with no cat or resonator. I'm not familiar with the catback you have, but I'm guessing it doesn't have a resonator either. Which means that the only thing quieting the exhaust is the muffler, which is not up to the task. If you want to run catless, try to find a front pipe that has a resonator in it. That'll help a little to calm things down. Two of the quietest aftermarket exhausts are the Perrin resonated and the Invidia Q300, which is also resonated. One of those and a resonated front pipe will make a difference. Having a catted and resonated front pipe will make more of a difference. The cat will help smooth out the rasp that you get from a UEL header that is running catless. If you want to go even quieter, get a catted header, catted and resonated front pipe, and one of the exhausts I just mentioned. This thread has a lot of youtube videos of different exhaust configurations. http://www.ft86club.com/forums/showthread.php?t=6064 |
Turbo 86
Drives: GT86
Nameless dp/op is your best option IMO.
10 - 1 = 0
real math |
#7 | |
Calle Atun
^ Gesus
It sounds like a plane. |
| Atermarket Speaker crossover install location | AL008 | Electronics | Audio | NAV | Infotainment | 9 | 10-17-2016 11:37 PM |
| namess vs AP crossover pipe? | thebear21 | Engine, Exhaust, Transmission | 92 | 08-15-2013 06:38 PM |
| Spot to hide crossover ?!!! | mashal | Electronics | Audio | NAV | Infotainment | 1 | 12-18-2012 12:00 AM |
| Factory amp crossover specs | JoeBoxer | Electronics | Audio | NAV | Infotainment | 0 | 09-23-2012 09:09 PM |
