Old 06-20-2020, 02:42 AM   #15
norcalpb
norcalpb's Avatar
Stop top hat =/= stock center nut. Depending on his shaft, it may be different, which may have a different torque spec.
OEM is M12x1.25, but Tein and JRZ are both M14x1.5. AST is typically M12x1.25, but not always.
Very true I haven’t even thought of that.
OP it looks like the 5100 series coilovers use an M12 nut.
Are you using the AST nut on the OEM top hat? It’s a long shot, but the AST nut arent flanged like the OEM nut. I know the factory top hats do not use a washer between the strut nut and upper top hat bearing, so the flanged nut may be needed to avoid spring bind 100% of the time? Long shot for sure, but I’d personally go through the trouble of putting the stock strut nuts on and listen for the noise.
norcalpb is online now   Reply With Quote
The Following User Says Thank You to norcalpb For This Useful Post:
tintumz22 (06-20-2020)
Old 06-20-2020, 01:23 PM   #16
DarkSunrise
DarkSunrise's Avatar
That's the exact noise I had when my top nuts were coming loose. Went away after I tightened them down again.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Old 06-20-2020, 01:34 PM   #17
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
I re torqued both side and they are in both 41ft lbs. Both side are using nyloc m12x1.25 nut. I tried test driving it again and the noise is still there. I was able to get in contact with the damper rebuilder and said to bring them back in to see if they can replicate the sound in their dyno and recheck them for me.
tintumz22 is offline   Reply With Quote
The Following User Says Thank You to tintumz22 For This Useful Post:
CSG Mike (06-21-2020)
Old 06-20-2020, 02:40 PM   #18
Racecomp Engineering
Since 5100s are inverted, I wonder if the other nut on the bottom is not properly torqued.
- Andrew
CSG Mike (06-21-2020), tintumz22 (06-20-2020)
Old 06-21-2020, 11:46 AM   #19
M0nk3y
FWIW - I had almost this same exact noise on my MCS 2-Way Remotes in the rear.
I chased the noise for 2 years. Thought it was shock but, then figured the sphericals on the top hat were shot. Replace endlinks in the rear too
Noise only occurred at low speed sub 35 mph. Worse as you slowed down and hit more uneven payment.
Sent my shocks into MCS for warranty and revalve because the fronts were leaking oil at the canister (V2 Canister design on V1 Seals)
Found the rear cans “slightly” leaking oil which most likely caused the noise by not letting the piston re-seat. We upgraded to a coated piston offering by MCS that wasn’t available to OTS builds to reduce initial nose in and they’ve been fantastic ever since
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
tintumz22 (06-21-2020)
Old 06-21-2020, 01:06 PM   #20
tintumz22
tintumz22's Avatar
I checked the nut from the bottom, being it as inverted and it was tight too. Hopefully, rebuilder can replicate the noise and figure it out what’s going on. It won’t be til Wednesday due to work. They said I can drop by anytime and they will look at it right away as soon as I bring it to them. I’ll update here.
Those are interesting info. I do not see any leaking oil so far.
Old 06-30-2020, 03:24 PM   #21
tintumz22
tintumz22's Avatar
Help identifying sound. Newly rebuilt coilovers installed.
Just updating. Rebuilder took the dampers in and checked it. They did dyno them even with the whole coilovers assembled. They were unable to reproduced the noise in the said video and graph shows that they are working fine. They replaced the top spring perch for the fronts just to see if that could be the cause due to a little play on them. The noise is still consistent in low speed and does sound like a loose top nut but they are all tight even at the bottom being an inverted dampers when I checked. I tried their advice of just installing the fronts and see if the noise is still there, and yes it was there but not much then when I installed the rears it was more apparent. I gave a triple check again when I installed them and all nuts and bolts are torqued to spec. Next step is bringing the car in and they will check it themselves and help me out sourcing that noise.
Code Monkey (06-30-2020)
Newly installed Apexi EXV N1 coilovers clunk noise when car’s cold stlgrym3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-02-2018 02:04 PM
Balance newly installed tires/rims golemslord Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-15-2016 06:44 PM
Newly installed problems JG Engine, Exhaust, Transmission 16 06-27-2015 12:33 PM
Feedback through newly installed tweeters mit_peid Electronics | Audio | NAV | Infotainment 24 04-07-2013 11:05 AM
