Old 06-19-2020, 07:01 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by DarkPira7e View Post
Fairly certain Nameless makes headers that are 3" where it meets the overpipe. Doesn't really matter, since you can just get a 3" overpipe and it'll go from 2.5" at the header to 3" at the overpipe.
The Nameless is 3", but they are only building them if they get enough interest. They had discontinued them for a while.
From their site.
OK WE ARE LISTENING. These are not currently in stock, but we have seen how many of you are searching for them, looking for used units, and downright begging us to pick up manufacturing them again. We will certainly consider it, and will consider a significant improvement to a 321 stainless alloy (Nickel, Chromium, Titanium alloy vs. the 304 which lacks Titanium). But we need enough people to get together and show interest in it before we move forward. So the first phase of this is to simply stop what you're doing right now and email us at research@namelessperformance.com. Get your name on the list. Let us know if you have any specific goals from the design. We will be doing a mild redesign of the system to bring the bending process in-house in order to offset the exorbitant cost of material in this updated alloy.
Old 06-19-2020, 07:20 PM   #16
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
From their site.
Huh, makes sense. I understand why they don't want to make them though, I imagine there's not really a benefit
Old 06-19-2020, 07:47 PM   #17
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
so what would the point of a 3" exhaust be if the headers are always going to be 2.5" max? i guess the cat might flow a little better?
Old 06-19-2020, 07:56 PM   #18
DarkPira7e
DarkPira7e's Avatar
Exhaust loses heat and velocity over distance. You'll get turbulence and lose exhaust scavenging if the exhaust is just a huge open pipe. Opening it where it starts losing velocity is not a bad idea though.
Old 06-19-2020, 08:03 PM   #19
Breadman
Breadman's Avatar
oh ok just wondering. i would have thought that it would be bad because making it wider would make it flow slower and cool down
Old 06-19-2020, 10:50 PM   #20
Joveen
Joveen's Avatar
Drives: Bone stock
PLM makes a 3" exit header. It was a copy if the nameless header. It's like $500 for iirc. But its EL. You could probably get a UEL of choice and have a shop fab up a 3" merge collector/exit for a full 3" system.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 06-20-2020, 08:29 AM   #21
Breadman
Breadman's Avatar
looked it up and that is real strange looking. i wonder how it works with a high boost pulley since that is the only real application for it
Adding in line fuel pressure regulator KGZ86 Engine, Exhaust, Transmission 13 07-07-2016 05:15 PM
Axle back exhaust feed back requested Gruppe-s Engine, Exhaust, Transmission 10 12-10-2014 07:56 PM
Back Pressure kalamitykode Engine, Exhaust, Transmission 24 11-16-2014 11:34 PM
exhaust sizing and back pressure some facts on the debate cdrazic93 Engine, Exhaust, Transmission 0 10-02-2014 02:21 PM
Not enough exhaust Back Pressure? Quiet car? mtimney Engine, Exhaust, Transmission 11 08-05-2013 11:10 PM
