Im getting a Full Blown stage 1 turbo kit which runs an over pipe with 3” of diameter, but I cant find a frontpipe that has a high flow cat at 3”, so I was gonna either:
- Run the front pipe at 2.5 and continue the line at 3” - Continue the whole line from the front pipe at 2.5 - or keep my borla cat back that goes from 2.5 to 2 and get a 2.5 front pipe Im just wondering if running any of does lines 7-8 psi will create to much back pressure... |
Drives: Bone stock
JDL makes 3" front pipe with high flow cat. You can get an Avo 3" with high flow cat. Google is a wonderful tool my friend.
Sent from my SM-N960U using Tapatalk |
Im dumb asf, for some reason google didn’t show me the jdl one but I went to the website and I see it now thanks bro. Do y’all think it should ve resonated or not
Drives: Bone stock
Up to you. Catted and resonated will definitely keep it quiter and deep toned. Dual resonated will definitely deepen the sound and keep it mildly quiet. I say dual resonated as it basically catless without drone and will make it sound better and keep cabin vibrations and drone down.
Rust bucket enthusiast
It's as Joveen says. But keep in mind, if you do an open dump wastegate ( not recirculated) none of your exhaust system will be deadening that sound. it's like a second exhaust that is about 6" long and it SCREAMS, but is only open when the wastegate opens (hopefully around your set boost level)
Look up videos of " open dump wastegate" to understand what I'm referring to. |
#6 | |
Drives: Q5 + BRZ + M796
Do recirculated or else you will sound like an obnoxious, screaming banshee.
#9 | |
I hope not.
#10 | |
If I had a recirculating exhaust, it wouldn't be very loud at all, but outside the car the noise can be heard very very far away. My car has an equal length header as well, which is more " honda" than you'll get with an unequal length header. |
#11 | |
#12 |
I have no blow off valve, the port is completely blocked off. So the air that is supposed to escape cannot. I was running it like that to test and ended up leaving it like that, I had no negative effects but I did not run it like that for more than a few months. I have no data to suggest whether or not it will harm the turbo compressor, so I would not recommend it until I can prove without a doubt that it would not harm something.
#13 |
Drives: 2017 BRZ w/PP
this is a dumb question and partially jacking the thread but do they even make headers with 3" exits for super charged engines?
#14 |
Fairly certain Nameless makes headers that are 3" where it meets the overpipe. Doesn't really matter, since you can just get a 3" overpipe and it'll go from 2.5" at the header to 3" at the overpipe.
| Adding in line fuel pressure regulator | KGZ86 | Engine, Exhaust, Transmission | 13 | 07-07-2016 05:15 PM |
| Axle back exhaust feed back requested | Gruppe-s | Engine, Exhaust, Transmission | 10 | 12-10-2014 07:56 PM |
| Back Pressure | kalamitykode | Engine, Exhaust, Transmission | 24 | 11-16-2014 11:34 PM |
| exhaust sizing and back pressure some facts on the debate | cdrazic93 | Engine, Exhaust, Transmission | 0 | 10-02-2014 02:21 PM |
| Not enough exhaust Back Pressure? Quiet car? | mtimney | Engine, Exhaust, Transmission | 11 | 08-05-2013 11:10 PM |
