Old 06-10-2020, 03:17 PM   #1
degozaru
Drives: 2016 oceanic frs
swaybar preload
Hey guys, I was wondering if anyone can school me on endlink preload. I just installed RSR Sports-i coilovers and love the handling it gives me. It would handle great UNTIL a certain point when traction control would kick in for seemingly no reason (I am certain the car had tons of grip remaining). I am guessing that the front sway bars are being preloaded and are causing trouble. Is there any way to tell for sure if this is the problem?
I might have not torqued the endlink correctly. I used a torque wrench, but I didn't have any way to hold the nut while I turned.
If it helps any, this is my sway bar with the car wheel turned into the car:
https://imgur.com/a/d99jNog
Thanks
degozaru is offline   Reply With Quote
Old 06-10-2020, 03:49 PM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
Drive up on ramps and adjust is what do for mine.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 06-10-2020, 03:52 PM   #3
jamal
jamal's Avatar
Drives: Legacy GT
If you have an adjustable endlink, you can get the car on a flat surface unbolt them, and take out any preload.
But before you get into that, has the car been corner balanced? Might want to do that first if not.
jamal is offline   Reply With Quote
Old 06-10-2020, 04:05 PM   #4
degozaru
I am using stock front endlinks. Want to know if I need the adjustable endlinks before i buy
The Following User Says Thank You to degozaru For This Useful Post:
Joveen (06-10-2020)
Old 06-10-2020, 04:10 PM   #5
Joveen
Joveen's Avatar
Drives: Bone stock
Usually you need adjustable endlinks for going low.
Old 06-10-2020, 04:20 PM   #6
Racecomp Engineering
Is your alignment okay? Got a printout?
Similar funky handling on left and right turns?
Any noises?
What you can do is unbolt the endlinks from the strut with the car in the air and then lower the car to the ground. Now see where the endlinks line up compared to the strut mounting points. If they're not close, that's an issue and you might want to consider adjustable endlinks.
- Andrew
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post:
degozaru (06-10-2020), Joveen (06-10-2020), sroby (06-19-2020), strat61caster (06-10-2020), wparsons (07-03-2020)
Old 06-10-2020, 04:56 PM   #7
degozaru
Any noises?
- Andrew
I believe that it is more noticable on a certain turn (I forgot if it was right or left turn, should go see). I do not have an alignment yet. I was hoping to fix up all the issues before getting it aligned, although it could be an alignment problem, so I will be aligning it soon.
Old 06-10-2020, 05:14 PM   #8
My first thought is alignment.
- Andrew
norcalpb (06-10-2020)
Old 06-10-2020, 06:17 PM   #9
norcalpb
norcalpb's Avatar
Just FYI, the only reason to wait for an alignment is to let the springs settle to their proper height. During this time you should not be pushing the car at all as that is extremely dangerous. I bet your tires are pointing in different directions like Crazy Eyes did the alignment himself.
Old 06-10-2020, 07:06 PM   #10
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
The traction control is more conservative than your racist grandpa, it is not a reliable indicator of any issues imho.
ineedyourdiddly
Old 06-10-2020, 07:45 PM   #11
cueball89
Drives: 15 Impreza
I found the traction control was more sensitive if the wheels and steering wheel were not pointing straight after suspension work. I fixed the alignment and the hypersensitivity went away.
cueball89 is offline   Reply With Quote
Old 06-10-2020, 08:31 PM   #12
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
If you're doing coilovers at the same time, do them first, then get a corner balanced alignment, THEN adjust your swaybar links for zero preload.
If no coilovers, then just adjust your links for zero preload, preferably on the alignment rack so you know you're level.
And if you're still on stock endlinks, then this question is academic, at best...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 06-10-2020, 08:33 PM   #13
venturaII
venturaII's Avatar
...and it should go without saying that whoever does your corner balancing should also be disconnecting your swaybars BEFOREHAND...
Old 06-10-2020, 09:53 PM   #14
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Lolwut
Tein Flex Z Preload Help! trinidadj Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 03-15-2017 10:44 PM
Coilover Preload collars keeps coming loose BDotG Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-21-2015 10:23 PM
Benefits of a right preload adjustment? Walla Walla Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-12-2015 10:39 PM
FS (MI): Front strano swaybar, rear wrx swaybar Aznsky Brakes, Suspension, Chassis 4 11-04-2014 02:09 PM
Stance SS coilovers preload? CyberAkuma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-16-2014 02:26 PM
