Old 02-26-2017, 08:51 PM   #1
trinidadj
Drives: '16 FRS-MT Ablaze Red
Tein Flex Z Preload Help!
I just picked up some Tein flex z coilovers from another member on the forum. I'm going to be install them this weekend. I wanted to know if anyone had the instruction manual. In particular I'm wondering how to adjust the preload to the factory settings or check it?
Thanks for the help!
trinidadj is offline   Reply With Quote
Old 02-27-2017, 03:39 AM   #2
tyler_win_photo
tyler_win_photo's Avatar
They recommend to turn the preload until it's "tight" then one more turn. Ymmv
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
zc06_kisstherain (02-27-2017)
Old 02-27-2017, 11:27 AM   #3
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
like typer said. but i tightend little more than default.
Old 02-27-2017, 11:56 AM   #4
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
The thread pitch on the collars is 1.5 and the recommended preload is about 2mm? So, with the collar tightened right up against the spring, another 1 and 1/3rd turn will get you about 2mm of preload. Check preload again after a week or so then do the process again.
Intent > Content
Old 03-01-2017, 10:14 AM   #5
trinidadj
Thanks for the help so far everyone! Should I worry about adjusting anything with the camber plate or just the let the alignment shop handle that? I'm also going to install some lower control arms so any tips on setting camber for those? (lower controls will the whiteline lcas not the spc re-branded ones but the original beefy ones they made in goldish color pictured below)
Old 03-01-2017, 10:35 AM   #6
trinidadj
Also I'll be running the stock wheels/tires so how low can I go with tein flex z coils and lcas before needing adjustable front end links and rear toe arms?
Old 03-01-2017, 11:37 AM   #7
strat61caster
strat61caster's Avatar
Match the length of the OE LCA's as close as possible, if you do then your alignment should be relatively close to what it was before you put them on allowing you to drive the car to the shop safely.
Be extra careful driving it to the shop, you may have made the car a bit unpredictable if you aren't close enough.
You will not need rear toe arms, OE is perfectly fine for any sane adjustment.
idk about the front swaybar endlinks but I don't see the point in slamming the car so someone else will have to tell you.
ineedyourdiddly
juenedgi (09-10-2022)
Old 03-01-2017, 08:45 PM   #8
trinidadj
Okay thanks for the response ill be sure to measure both. I'll be on stock tires/wheels and I'm looking to drop the car to the factory height of 1.3" that the tein's come preset with. I would like to have -1.5 degrees of camber up front and -1.0 in the back (or should I go more i'll just be DDing for now). Also does anyone have the instruction manual for the tein flex z that shows the factory ride height adjustment? (Like those A,B,C,D positions and measurements). I cleaned the threads and doing so moved the locking collars and base to various positions.
Old 03-01-2017, 10:25 PM   #9
bored@work84
bored@work84's Avatar
Drives: H8R 86
you can go online to tein's website and they should have all their manuals available to view
bored@work84 is offline   Reply With Quote
Old 03-02-2017, 01:27 AM   #10
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I can't seem to find manuals on Tein's US website. Can you give a link?
Old 03-02-2017, 07:12 AM   #11
trinidadj
I'm having trouble locating them also. I swear I've looked everywhere!
Old 03-02-2017, 11:28 AM   #12
bored@work84
Drives: H8R 86
http://www.tein.com/tech_info/
http://www.tein.com/tech_info/q54.html
http://www.tein.com/tech_info/sa0.html
Old 03-02-2017, 01:01 PM   #13
trinidadj
Thanks for that info I did actually come across that while browsing the site. I'm really looking for the diagram that has the factory collar measurements like the one pictured below(this is for a totally random car have no idea!). If anyone who has the manual will you please snap a pic of those diagrams or list the data out. If it is available online will someone please point in the right direction. I'm looking to install Saturday!
Old 03-02-2017, 03:11 PM   #14
trinidadj
Originally Posted by zc06_kisstherain View Post
yes. make sure pre-load ring is snug not loose.
I slightly increased pre-load from default though.
between 2nd collar ring to bottom collar, it's 28mm on front and 35mm rear.
when i lowered mine, front gap seems little higher than rear. try 25mm or 26mm at front and should be looking similar to rear but i havent adjusted anything yet. lol
I have sti lips around and front lip still doesnt seem like very low enough to scrap anything but if i lower 0.5 inch more, i would scrap everything..haha
After searching I was able to find this. Thanks to zc06_kisstherain.
I'm going to take a pic of the coilovers with a drawn diagram showing the measurements between collars. Please still post the diagram and table if anyone out there has it.
Tein Flex A DeaconRoc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 138 04-12-2018 05:23 AM
WTB Tein Flex Z HachiRo Want-To-Buy Requests 1 09-19-2016 01:13 PM
tein flex z mclovin85 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-14-2016 06:27 PM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 09:33 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
