Drives: Asphalt 2013 FR-S
Coilover Preload collars keeps coming loose
I am at a loss here folks. No results seem to show any good solutions so I am hoping someone here can chime in.
My coilovers preload collars keep coming loose after like 2 weeks of driving. Whereas there was about 1/2 gap between the height and preload adjustment collars, there is none now. I have torqued them to Teins recommended settings the 4 times I have reset the preload, and last time I had my friend hold one spanner while I hammered the other. This is only happening on the fronts. What. the. $%*^. |
Drives: Scion FRS
Do not hammer. If you attach a ratchet where there is a square hole on the spanner, it will give you a ton of leverage to tighten it to a point where it wont move anymore. I had a similar problem when I had just installed my Tein coilovers. It was only the front that kept coming lose. After doing the method above, it has not moved at all for 6 months.
| The Following User Says Thank You to babykwiss For This Useful Post: | BDotG (11-23-2015) |
| Spec d spoiler keeps coming loose | select20 | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 10-23-2015 12:28 PM |
| Benefits of a right preload adjustment? | Walla Walla | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-12-2015 10:39 PM |
| steering wheel coming partially loose | balci | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 03-30-2015 02:11 PM |
| Red stitching is coming loose. | Chip | Issues | Warranty | Recalls / TSB | 7 | 11-01-2012 10:02 AM |
| Camshaft Bolt Coming Loose After Perrin Pulley Install | WhiteBRZ | Engine, Exhaust, Transmission | 25 | 09-20-2012 08:07 AM |
