Old 05-12-2015, 07:14 PM   #1
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
Benefits of a right preload adjustment?
i've installed my HSD coilover lately, and i'm trying to find good information about preload setup
with all the page I read, i can now say that i understand what it is, and how we should calculate it, but i never find any information about what will be the benefits of a right preload setup
If i preload my spring for the right weight on each corner, yes my suspension will work and my shock will have more travel, but what difference will i see in the driving? is their a gain, or it wont make a difference except the suspension will work better, have less risk of bottoming out?
what will happen if i put to much preload? what will happen if i do not put just not enough preload? will i see a difference behind the wheel?
i want to take time and corner weight my car to adjust it correctly, but will i see a real difference, and are there better adjustment to do with it than to preload the weight of the car?
Walla Walla is offline   Reply With Quote
Old 05-12-2015, 09:29 PM   #2
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
HSD's are 6/6 kg/mm coilovers, with a similar amount of travel to the BC Clone Army. That's ~4 inches.
The stock car is ~2.3/3.7 kg/mm, with ~6 inches of travel. Our estimate of travel has not been officially confirmed.
Car mass is ~300 kg/wheel, so you're compressing the HSD's by 50mm (50% travel). Similarly, stock springs will compress by 100mm (67% travel).
Both setups will have ~2" of travel in compression, but the stock setup will run into bump stops easier (due to the softer rates). Stock setup has more rebound/extension travel, which is a great ratio for a street vehicle.
Without progressive springs, there's not a huge benefit to using pre-load, and it only serves to limit compression travel, which there isn't alot of.
Moral of the story: You don't really need any pre-load, but if you want it, keep it between 0.0 - 0.5". You don't want loose springs, but running out of compression travel isn't fun either.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 05-12-2015, 10:39 PM   #3
kster1
kster1's Avatar
You don't normally play with the preload to set the weight of each corner. I usually set a few turns of preload so that under full compression, the opposite side spring isn't loose and bouncing around at full droop (as @Shankenstein said).
Once preload is set, you can optionally set the weight of each corner by playing with the ride height adjustment (typically it's a lower lock ring). You will need scales for this to set the cross weights; or take it to a race prep shop.
kster1 is offline   Reply With Quote
Roll centre adjustment - options & benefits? ultra Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 08-16-2015 11:56 PM
Stance SS coilovers preload? CyberAkuma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-16-2014 02:26 PM
Benefits of E85? Whitesoul Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 07-07-2014 10:03 PM
Modify Preload on Brand new Coilvers or Leav Alone? Measurement to get 1 finger Gap? taimysho0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-07-2013 10:40 PM
Benefits of a cleaning Ben_G Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 08-19-2012 03:14 PM
