Old 07-23-2012, 08:27 PM   #85
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
Taking another look at it, I figured it out. I think those dimples on the edge for the static timing. Advancing or retarding the time & those stand for the degrees & limits of advancing & retarding I believe. They used to put little notches on the lip, I'm going to throw out a random guess & say that's what I think it is
karma003 is offline   Reply With Quote
Old 07-23-2012, 08:32 PM   #86
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by karma003 View Post
I used to be a technician at a Toyota dealer, I didn't do too many engine rebuilds due to the fact that Toyotas r pretty reliable, (& most were given to my buddy the master tech there.) But to my recollection, they weren't ment for any kind of balancing I don't think.
First, remember that this is a Subaru engine block, so don't expect the same behavior as with a Toyota engine (NOT saying that they are not the same but just make no assumptions based on previous Toyota engines because this part of the engine is not Toyota). Looking at the car engine manual on page 28 of the PDF (Page EM-19 on the manual), the tool does not seem to attach to those holes.
Edit: You are most probably right that the Pulley is balanced by itself. We are just looking here for direct and exact confirmation that it is.
You might be right on this as I have not really dealt with timing a car for SOME years now and never with a Subaru/Toyota.
Old 07-23-2012, 08:36 PM   #87
karma003
karma003's Avatar
You might be right on this as I have not really dealt with timing a car for SOME years now.
Lol last cars I was timing were 90's models. My miata & buddy's 240sx & of coarse plenty of older Toyotas. I'm not sure if things have changed or not, & considering there isn't a distributor anymore (but Idk if Subaru still does do them, Idk) then I don't understand the perpose of having static timing dimples/notches on the balancer for? &
Old 07-23-2012, 08:38 PM   #88
Sportsguy83
Drives: Limited BRZ
^^ I edited my post above while you were quoting me.
Old 07-23-2012, 08:49 PM   #89
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
This looks like a cast part that requires balancing on it's own and has to be independent of the internal crank balancing.
To prove this, I suggest you compare a few pulleys. If the balancing drill marks are in different places and vary in depth then it is most certainly as I'd suspect. In no way would that be reliant or matched to a single motor...
CircuitJerk is offline   Reply With Quote
Old 07-23-2012, 08:50 PM   #90
karma003
karma003's Avatar
Lol oh ok, well yea. I mean I'm not the engineer or anything. Buy I wouldnt think they'd expect holes to balance out a whole motor. Only 2 small dimples at that.
Old 07-23-2012, 08:51 PM   #91
karma003
karma003's Avatar
That's what I ment by how would one go about buying a new pulley if each pulley was specific to the motor it came w
The Following User Says Thank You to karma003 For This Useful Post:
CircuitJerk (07-23-2012)
Old 07-23-2012, 08:57 PM   #92
CircuitJerk
Pull my finger...
My apologies, I may have skipped a few posts.
Old 07-23-2012, 08:59 PM   #93
Sportsguy83
Drives: Limited BRZ
I definitely agree with your logic. We just want exact confirmation this is the case. Remember, a crank pulley is not something that you replace if ever on an engine. I do know by fact that motor builders sometimes balance pistons, crank, pulley, rods, flywheel and some even go as far as clutch assembly. BUT I have no idea if any car manufacturer would go as far as the pulley on balancing (logically seems they wouldn't). Also, I'm not bashing the pulley as there are nothing but positive reviews about it around the web. I just like having all information at hand. :happy0180:
Old 07-23-2012, 08:59 PM   #94
karma003
karma003's Avatar
Lol its ok, I did too
Old 07-23-2012, 09:02 PM   #95
karma003
karma003's Avatar
Lol that's understandable, but I think ur going to find it vary hard to prove this.. I guess "theory" if I'm sure even the engineers thought of it to be common sense. Idk where u would go to look up that kind of basic info
Old 07-23-2012, 09:57 PM   #96
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Incorrect. It depends on the number of cylinders and configuration. Inline 4; unbalanced. Inline 6;balanced. As for vees it depends on on number of cylinders and vee angle.
I believe this is incorrect & the lad is right but made a typo when one is heading back ones heading out. Meaning that its using the law of physics what's in motion stays in motion. & for every action there's an equal & opposite reaction. So the force is never lost, but helps keep the motor keep moving more smoothly. As for v shaped & inline motors, the forces r thrown into a random counter in the motor & the pistion going up at the same moment is thrown off
http://www.zhome.com/ZCMnL/tech/harmonics.htm
http://what-when-how.com/automobile/...ce-automobile/
"Vibrations not normally included in either primary or secondary balance include the uneven firing patterns inherent in some configurations.
The above definitions exclude the dynamic effects due to flexure of the crankshaft and block and other force induced deformations."
https://en.wikipedia.org/wiki/Engine_balance
Old 07-24-2012, 01:58 AM   #97
Mongo
Mongo's Avatar
fyi - If you are like me and got one of the early packaged pulleys. the instructions don't give you torque specs. The newer packaged pulleys give full directions
Spoke to Perrin, they told me to oil the bolt (no brainer) and start at 33 foot pounds. Then from 33 pounds go to 94 pounds (should get at least a 45deg turn from 33 to 94 if not replace your bolt).
I would also mention the crank bolt is on there really good a good size cheater bar made life a lot easier.
also Perrin said there pulley isn't balanced. (may have already been confirmed, i might have skipped a few posts)
To anyone still trying to decide on this mod. Its a 100 dollars well spent. A definite improvement in throttle response.
Mongo is offline   Reply With Quote
The Following 4 Users Say Thank You to Mongo For This Useful Post:
86drift (07-24-2012), Sportsguy83 (07-24-2012), white devil (07-26-2012), XtremeMaC (12-10-2014)
Old 07-24-2012, 02:14 AM   #98
Enigmus
Enigmus's Avatar
Drives: 1996 Integra LS 4DR, 2013 Scion FRS
Here's my DIY for installing the Perrin crank pulley.
http://www.ft86club.com/forums/showthread.php?t=12583
Very easy and a nice upgrade! worth every penny!
Enigmus is offline   Reply With Quote
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
pulley installed issue Sall Issues | Warranty | Recalls / TSB 31 08-14-2012 11:36 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
