follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > DIY (Do-It-Yourself) Guides
Old 07-24-2012, 01:05 AM   #1
Enigmus
Enigmus's Avatar
Drives: 1996 Integra LS 4DR, 2013 Scion FRS
Aftermarket Crank Pulley Install
I just received my Light Weight Crank Pulley in the mail today. Decided to make a DIY tutorial for those who need a visual walkthrough. The most I've ever done to an engine was change a fuel filter and alternator on an integra years ago. This was a bit of a scary endeavor that worried me but I felt brave enough after carefully reading through the 2 page installation guide provided.
Tools needed:
Flat head screwdriver
Phillips head screwdriver
10mm socket wrench
Breaker Bar **
1/2" Torque Wrench**
14mm socket 1/2" Drive
22mm sock 1/2" Drive
** I didn't own my own breaker bar or torque wrench but for a $125 dollar refundable deposit you can borrow one from Autozone!
We will start by loosening the screws circled in blue that holds the intake and resonator tube together. Uncouple the oxygen sensor from the intake as denoted by the green arrow. Then use the 10mm socket to remove screws circled in red the resonator box and air intake (the third screw is to the right and is a bit of a squeeze to reach).
Remove the air intake and then move the tubing off to the right side.
With the intake out of the way you can see the tensioner pulley in blue and the crank pulley in red. We'll have to loosen the belt first by moving the tensioner pulley (note: not removing or loosening the bolt holding the tensioner pulley)
Using the breaker bar and the 14mm socket, turn it clockwise. When you apply leverage with the breaker bar it will move the whole tensioner pulley to the left giving slack to the belt. Slide out the belt from tensioner pulley and let go of the break bar gently. The tensioner pulley will slide back into it's normal spot.
Here is how the belt will look when loosened.
Now make sure the car is in 6th so the crank will not turn when you loosen the bolt. With the breaker arm and the 22mm socket, you will need a good tug counter-clockwise to loosen the bolt. It will feel spongy because of the crank slightly turning but with the car in 6th gear it will not spin freely. Give a good yank.
Word of warning: It will require a bit of force so much so that tennis shoes are required to give you grip. And don't wear a belt or jeans! you'll risk scratching your bumper!
Once it's loosened you can remove and set aside the bolt and crank pulley shown below. Be careful as they will be hot to the touch if you have recently driven your FRS/BRZ!
Admire the differences in weight and finish between the OEM and new crank pulleys!
To install the crank pulley you will have to line up the key hole show above. Make sure the crank pulley is facing the right away with the threading inwards.
In the case of the crank pulley lettering logos should be facing towards the front. With the crank pulley aligned with the keyhold correctly it should not be able to turn freely at all.
Get some motor oil and grease up the threads and flat surface of the bolt head before inserting back into the pulley.
You will need to torque the bolt to 94lbs. Those of you not familiar with torque wrenchs you will turn the black grip until the zero "0" lines up with the 85 marking shown above. You then turn the grip until the 9 is lined up center. 85+9 = 94lbs
I must of forgotten to take a pic of this step but it is pretty straight forward. Using the torque wrench and 22mm socket you tighten it until you feel and hear a distinctive click.
Now you will have to use the breaker bar and 14mm socket and move the tensioner pulley just enough so the belt can reseat onto all the pulleys. It will be a little tough as you seat the belt on one pulley and it comes loose off another pulley. Quite Annoying but use the reference picture below of how the belt should line up.
Inspect the belt and make sure it is seated properly on all the pulleys before reassembling the air intake and resonators in reverse order. Remember to reattach the oxygen sensor or you will get CEL. Start the engine up and watch the crank pulley and belt. If all goes well you have installed an awesome and very affordable upgrade to your FRS/BRZ!
Return breaker bar and torque wrench to autozone and get your money back! Drive back home the long way and laugh maniacally as you wide open throttle every chance you get with your new crank pulley!
Enjoy!
Enigmus is offline   Reply With Quote
The Following 69 Users Say Thank You to Enigmus For This Useful Post:
AbsolutKev86 (03-12-2013), Anthonytpt (03-30-2013), Ash (11-03-2012), ATL BRZ (07-24-2012), b.e (10-15-2012), BAE (07-30-2012), baldolera (08-19-2012), Black Tire (08-02-2012), Bluecille (01-08-2013), blu_ (08-04-2012), bobpuffer (03-13-2013), Bonburner (07-24-2012), CamryDS (04-07-2013), CaptainSlow (02-09-2013), Captain_Awesome_Pants (02-18-2013), cfusionpm (05-02-2013), Chewie4299 (02-28-2013), chimmay (11-10-2012), danthedirt (07-24-2012), DriftEm (04-16-2013), EN2_Squirrel (09-14-2012), eriktherod (07-25-2012), Extreme86 (07-24-2012), FRS_Ken (10-23-2012), genometuning (10-09-2012), GregV (08-26-2012), Hawaiian (07-24-2012), Hook (03-03-2013), ill86 (09-15-2012), IShouldStudy (10-09-2012), japino123 (08-02-2012), Jayde (07-24-2012), jinrawke (07-24-2012), JohnATL (07-24-2012), Justin91M (12-07-2012), kevinnivek8877 (07-30-2012), kwood9000 (07-24-2012), LeavingNormal (07-25-2012), LeeMaster (10-08-2012), Marrk (08-29-2012), MattR (08-08-2012), Mburolla (07-31-2012), Mike86 (02-23-2013), Mitch (07-31-2012), ML (11-28-2012), neutron256 (07-24-2012), nubbster927 (07-30-2012), Obja (09-21-2012), PERRIN_Chris (07-24-2012), R2RO (09-30-2012), rocketballoon (09-15-2012), ScionFamily (01-28-2013), Scooby South (07-24-2012), sharris721 (03-23-2013), shawnperolis (03-18-2013), ShoNUFF (04-13-2013), Shutter (05-09-2013), Sideways? (11-28-2012), Snoopyalien24 (12-27-2012), Sonolin (02-23-2013), Sportsguy83 (07-24-2012), StarsGarrador (08-10-2012), TPO (07-31-2012), tripjammer (08-08-2012), Wes (07-24-2012), whataboutbob (08-10-2012), WolfsFang (10-04-2012), Yruyur (09-15-2012), zoomzoomers (08-29-2012)
Old 07-24-2012, 01:29 AM   #2
Sportsguy83
SE Region Moderator
Sportsguy83's Avatar
Drives: Limited BRZ
Extremely well written DIY! I installed it last week and did not oil the bolt ..( no instructions with my package), but its all good. I won't be taking it out any time soon.
-- David --
Build Thread: Sportsguy's Blue FI Dream
Sportsguy83 is online now   Reply With Quote
Old 07-24-2012, 01:50 AM   #3
mediumbrown
mediumbrown's Avatar
Drives: 2013 Argento Scion FR-S
why not leave the tension on the belt while you break the bolt loose, once loose then you can adjust the tensioner... this should help keep the crank from moving....
or use the impact to zing it off lol
mediumbrown is offline   Reply With Quote
The Following User Says Thank You to mediumbrown For This Useful Post:
Sall (07-24-2012)
Old 07-24-2012, 05:44 AM   #4
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
Originally Posted by Enigmus View Post
I just received my Perrin Performance Crank Pulley in the mail today. Decided to make a DIY tutorial for those who need a visual walkthrough. The most I've ever done to an engine was change a fuel filter and alternator on an integra years ago. This was a bit of a scary endeavor that worried me but I felt brave enough after carefully reading through the 2 page installation guide provided by Perrin.
Enjoy!
As a Toyota Tech i have to say this is one of the best DIY write ups great job with helping other. I guess that is why we are all apart of this club.
20valvewynn83 is offline   Reply With Quote
Old 07-24-2012, 07:14 AM   #5
ATL BRZ
HPDE Instructor
ATL BRZ's Avatar
Drives: '13 Black BRZ
Did you really have to quote the entire diy writeup to say thanks?? Lol jeez I am also very thankful to the OP. My pulley is waiting to go on my BRZ when I take delivery next week! I cant wait!
The Following 4 Users Say Thank You to ATL BRZ For This Useful Post:
civicdrivr (07-24-2012), DarthNads (07-24-2012), PERRIN_Chris (07-24-2012), StarsGarrador (08-10-2012)
Old 07-24-2012, 07:27 AM   #6
kwood9000
kwood9000's Avatar
Drives: Limited WRB AT6 BRZ
Great DIY write-up...thanks!
kwood9000 is offline   Reply With Quote
Old 07-24-2012, 07:30 AM   #7
civicdrivr
Lightness is a sickness
civicdrivr's Avatar
Drives: 03 Acura CL-S6 & 13 Scion FR-S 6MT
I saw in the Perrin instructions that it should be torqued to the same value you posted, however the manual says 14.5lbs-ft , then tighten an additional 90*. Anyone know which to go with? I assume turning it an additional 90* brings the force to nearly the same amount, but....
Sent from my Nexus S using Tapatalk 2
2003 NBP Acura CL-S 6MT, very very sleepy, 1 of 480
2013 FR-S 6MT, Asphalt, First 86
civicdrivr is offline   Reply With Quote
Old 07-24-2012, 10:37 AM   #8
Vino
3stars & a sun
Drives: FRS
NIce write up thanks to the op
Vino is offline   Reply With Quote
Old 07-24-2012, 11:38 AM   #9
20valvewynn83
Sorry bro didn't realise I did that.
The Following User Says Thank You to 20valvewynn83 For This Useful Post:
Sportsguy83 (07-25-2012)
Old 07-24-2012, 01:15 PM   #10
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Drives: 13 BRZ Limited, 98 Honda Civic
So what kind of difference are you seeing with this pully. Awesome write up.
TouchMyHonda is offline   Reply With Quote
Old 07-24-2012, 02:35 PM   #11
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
is the perrin pulley balanced for the car? the oem balancer should be perfectly balance and i was curious if this new one would throw it off at all. anyone know by chance?
driftartist is offline   Reply With Quote
The Following 2 Users Say Thank You to driftartist For This Useful Post:
ravenblackfrs (01-01-2013), TouchMyHonda (07-24-2012)
Old 07-24-2012, 02:42 PM   #12
kwood9000
kwood9000's Avatar
From what someone posted in another thread, the Perrin crank pulley is not balanced. However, no one has mentioned any problems with it, yet.
Old 07-24-2012, 03:26 PM   #13
TouchMyHonda
Vtec Jesus
I have a feeling this probably didn't give you close to 27whp LOL
Old 07-24-2012, 04:13 PM   #14
OrbitalEllipses
I'm different, yeah I'm..
OrbitalEllipses's Avatar
Drives: Attitude
You need a lightweight flyweight AND the pulley, dummy!
Old 07-24-2012, 04:43 PM   #15
TouchMyHonda
Vtec Jesus
OH RIGHTTTTTT
Old 07-24-2012, 05:50 PM   #16
Enigmus
Enigmus's Avatar
I doubt you needed to oil it anyways since it's practically a brand new engine but it's probably for peace of mind. How are you liking the new pulley?
I don't know about leaving the tension on when i break the bolt loose, but it's already stiff with it in 6th gear. Yes an impact gun is easier but a breaker bar would be easier to get access to for the rest of us without a nice gun and compressor.
thanks! I hope it really helps people avoid mishaps and share any tips and criticisms I may have left out!
haha he can always re-edit and remove the img /img tags. congrats on your brz! drive it stock and maybe break it in before you install the pulley?
you're welcome!
the way torque works is it is not additive. you just push until you hear a click. The whole initial 33lbs part and note the 45 degree turn I think applies to older worn engines. The bolt is practically new I don't think you need to worry about replacing it unless you fubar'd it. maybe someone can clear it up for us?
thanks, I will clean it up a bit and add missing pictures and steps when I do some local pulley installs for whoever needs them.
So far the first three gears feel... "peppy" it certainly feels more nimble and quicker to get me to 5k-7.4k range. I'll have to drive more spirited. I've never hoped for more red lights before.. lol
I haven't heard of anyone having catastrophic damages done on the forums.. and I believe Perrin to be highly regarded by the Nasioc community. Yes there will be those .01% failure rates but it's the risk we take for the enjoyment of our cars!
OH RIGHTTTTTT
LOL *cough* keep it clean guys. don't wanna start a new fresh thread now...
The Following User Says Thank You to Enigmus For This Useful Post:
Old 07-24-2012, 07:11 PM   #17
OrbitalEllipses
Drives: Attitude
Regarding "balance" of the crank pulley: most engine configurations vibrate to hell, in order to lessen this manufacturers often have a dual purpose crank pulley. That is, the crank pulley also acts as a harmonic dampener to reduce the vibrations inherent to the engine design. Recall, I said most engine designs have vibrations; the horizontal/opposed-piston/flat engine does NOT. Therefore, the pulley doesn't need to act as a harmonic dampener. When queried about this in the early 2000s, SOA stated that the pulley was NOT a harmonic dampener. So people should stop talking about balance.
Issues seen with crank pulleys in Subaru applications typically manifest as misfires or ghost misfires/CELs, usually when used in conjunction with lightweight flywheels.
The Following 3 Users Say Thank You to OrbitalEllipses For This Useful Post:
Anthonytpt (03-30-2013), Jayde (07-24-2012), Sonolin (02-23-2013)
Old 07-24-2012, 09:52 PM   #18
Jayde
Jayde's Avatar
Wow, compared to my friend's Si that we'll be changing that crank pulley on, this is a breeze! Thanks for the write up!
Jayde is offline   Reply With Quote
Old 07-24-2012, 10:08 PM   #19
RAN94A
Grand PooBah
RAN94A's Avatar
Drives: Toyota 86 GT MT
lol... edit your post where you quoted the WHHOLE thing.. and remove the images so this is readable.
RAN94A is offline   Reply With Quote
Old 07-25-2012, 12:59 AM   #20
Snaps
Supra Owner
Snaps's Avatar
Drives: 1995 Toyota Supra UK Spec
Wrong... A pulley can still be unbalanced without the shape of the material being the cause. Think of the reason you get a wheel balanced when you change tyres - it's to make sure the whole wheel is balanced around the central axis. A poorly balanced wheel can shudder and vibrate while driving, it can also reduce the life of things like wheel bearings and suspension bushes as a result... However, due to the relatively small inertia of the pulley compared to the crank, and the fact that the pulley is probably not far out of balance in the first place, it shouldn't matter.
As for the adding oil to the thread of the crank bolt, also a bad idea.. Adding oil modifies the friction of the threads, meaning you overtorque the bolt (as with the oil you have to tighten the bolt more until the same torque registers on the torque wrench). You should not add oil unless it was stated in the install instructions.
Finally, in general, when a bolt is told to be torqued to a certain torque spec, and then turned through another angle, it is generally not good to reuse that bolt. The extra turn usually causes the bolt to undergo plastic deformation - ie. the bolt stretches (as with head studs/bolts), which has usually been done when the pulley was first installed from factory. This will probably not matter either.. I'm sure Perrin would have done their research when they came up with the instructions.
Snaps is offline   Reply With Quote
Old 07-25-2012, 01:00 AM   #21
DarrenDriven
Evil Asphalt
DarrenDriven's Avatar
Drives: 2013 FR-S Asphalt
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 07-25-2012, 01:10 AM   #22
Sportsguy83
SE Region Moderator
Drives: Limited BRZ
Perrin's instructions call for oiling it.
-- David --
brz, crank pulley, diy, frs, perrin
Search this Thread:
Advanced Search
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission, ECU 94 01-30-2013 05:39 PM
PERRIN Light Weight Crank Pulley **Now Available** PERRIN Engine, Exhaust, Bolt-Ons 5 09-13-2012 11:47 AM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 02:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 09:24 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
