Sallbaru
Drives: raven FRS
pulley installed issue
ok so my problem comes by installing perrins pulley i cant pull out my stock pulley maybe is too damn hard or idk.but i couldnt do it my self
so i decided to go to a mechanic and pay him to do it.but he couldnt take it out either and also the idiot was trying to pull it on the wrong way not clockwise,he even try to heat the bolt (idk is this is wrong to do )okay so im asking if someone knows a trick or something to take out my stock pulley and finally installed perrins pulley .my frs is manual.thanks in advance....
i'm sorry, what?
Drives: Canada
i think your mechanic just fucked up your car mang
here is a subaru application, i can't imagine it being too different. http://www.rs25.com/forums/f105/t113...ml#post1774930
#3 | |
Sallbaru
Drives: raven FRS
i'm sorry, what?
Drives: Canada
did he blow-torche the crankshaft bolt until it was red hot?
Sallbaru
Drives: raven FRS
no he just heat it up alittle bit.is my first time changing a pulley i didnt thought it will be this difficult i have asked many mechanics and they all say they need to removed the front bumper and vents ......
Re-member
Drives: Toyota camry
That mechanic sounds like an idiot.
Nothing decays like progress, and nothing preserves like neglect.
Sallbaru
Drives: raven FRS
i'm sorry, what?
Drives: Canada
take your car to a subaru shop, it looks like your mechanic doesn't know shit fuck all on how to work with boxer engines.
Sallbaru
Drives: raven FRS
#10 |
i'm sorry, what?
Drives: Canada
it is simple if you use the right tools and know how to use them.
#11 |
Sallbaru
Drives: raven FRS
is there someone in socal that has installed this please let me know thanks...
#12 |
Drives: 128i, Z3 Coupe, Fiero GT
Have you called Perrin for advice?
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT 2017 Pirelli World Challenge TC Rookie of the Year 2012 NASA SpecE30 National Champion www.DriveFasterNow.com |
#13 |
Drives: 2013 BRZ, 2002 WRX
Heating the bolt? That's the opposite of what he'd need to do.
Just need to pick up a pulley tool that will keep the pulley from rotating while leaning on it with a breaker bar. I was able to remove mine by putting car in 5th gear and cranking on the hand brake as hard as I could. That bolt is seriously on there!
#14 |
Drives: 2013 Subaru BRZ - DGM
I ended up using my torque wrench to get it loose. It was the only wrench long enough to get the necessary leverage on the bolt.
I bet it had over 125 lbs of torque on it from the factory. |
| Perrin Crank Pulley now available | milenko11 | Engine, Exhaust, Transmission | 96 | 12-10-2017 06:45 PM |
| Crank Pulley and the warranty | Brimford | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 07-08-2012 03:47 PM |
| Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 | Redline360 | Engine, Exhaust, Bolt-Ons | 2 | 07-07-2012 10:24 PM |
| BRZ LED lights installed | KI_ZN6 | Cosmetic Modification (Interior/Exterior/Lighting) | 24 | 07-04-2012 05:34 PM |
