Old 05-06-2020, 03:52 AM   #1
Alastor
Alastor's Avatar
Drives: Toyota gt86 my19
Armrest creak
Hi
At the time I installed the Toyota oem armrest. After a while it started to squeak when opening or closing it, I solved it several times with lubricant, but it always reappears after a month or two months.
Does anyone have the same problem?
At the time I saw a video where you could see how they opened and closed and also made noise.
Is there no solution?
Has anyone installed the copy of the oem armrest?
Thanks
Alastor is offline   Reply With Quote
Old 05-06-2020, 05:37 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, i'd check if some bolts/nuts may need retighten. Both for bezel that attaches to console, and especially so those on "cover/door".
Old 05-06-2020, 08:09 AM   #3
Alastor
Alastor's Avatar
Thanks for the reply.
Do you also have the armrest?
Everything is tight, I already tried it in time.
In this video you can hear the noise, minute 6:58
And this first minutes
This minute 5:19
More
Which makes me think that the construction of this armrest is not good and ends up making noise.
Old 05-06-2020, 09:05 AM   #4
AJ32162
Drives: 2019 BRZ with Performance Package
My armrest makes the same 'creaking' noise. It never concerned me.
AJ32162 is offline   Reply With Quote
Old 05-06-2020, 09:50 AM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It's the design of the arm rest. Have you tried white lithium grease? I don't know what lubricant you're using, but it may not be a lubricant at all. Turn the music up or get a louder exhaust
Yoshoobaroo (05-06-2020)
Old 05-06-2020, 11:12 AM   #6
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
This, a lot of products marketed as lubricants are actually solvents.
Old 05-06-2020, 11:13 AM   #7
Alastor
Alastor's Avatar
I have used 2 types of lubricant, one for white plastic grease and the other the 3 in 1 as usual.
and it's reappearing. with heat it expands and you hear less but when it is cold you can see it more.
Old 05-06-2020, 12:01 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
I know, that small issues might be getting on nerves for some people.. but i probably wouldn't care about any creaking when opening/closing. At most, if maybe it creaks also when one puts arm on that armrest (though that doesn't matter to me much either, as most of a time i try to drive with both hands on the wheel), as that might be more frequent then opening/closing, and "compromises" "main function".
It does the job of visually closing that recess mid console with blending in oem-looks, on those rare occasions i do use it as .. well, armrest , it seems just the right height to reach for gearshift or handbrake, and was dirt cheap .. creaks .. there can be more annoying noises in these cars. . Even if mine on open/close also creaks, i still don't regret of getting/installing it. If anything, only thing i'd wish would be for it to open not sideways, but rearwards. Creaking doesn't bother me enough to care to fix.
Old 05-06-2020, 01:22 PM   #9
Alastor
Alastor's Avatar
Hi
In my old avensis had armrest and was better than this, now.
Old 05-06-2020, 04:46 PM   #10
gpvecchi
gpvecchi's Avatar
This really annoys me, but I still haven't a solution...
Old 05-06-2020, 08:48 PM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
i just turn the radio up, or drop a gear and make the motor sing.
Old 05-07-2020, 03:34 AM   #12
Alastor
Alastor's Avatar
Is the same, I open armrest before of turn on.: bonk:
Old 05-07-2020, 05:36 AM   #13
JD001
JD001's Avatar
Drives: Subaru BRZ
Sounds to me like a case of "tennis elbow"...
Old 05-07-2020, 10:33 AM   #14
ls1ac
ls1ac's Avatar
Have you tried a dry silicone lubricant? Spray on and it dries. Plastic to plastic will often squeak.
Dash/firewall creak norcalpb Issues | Warranty | Recalls / TSB 5 10-14-2019 05:16 PM
Steering Column Creak michaelahess Issues | Warranty | Recalls / TSB 12 06-27-2018 01:14 AM
WTB: OEM armrest or Sutty's custom armrest J.C. Want-To-Buy Requests 0 10-20-2014 06:07 PM
Creak/Clunk heard after increasing throttle, recent springs install tracerit Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-10-2013 03:03 PM
Seat belt Receptacle Creak Wes Issues | Warranty | Recalls / TSB 2 05-21-2013 06:25 PM
