Old 04-28-2020, 06:07 PM   #1
02maher
02maher's Avatar
Drives: Gt86 2013
Question No start No crank Anti-theft blinking
Hello everyone,
I am trying to start my 2013 manual Gt86 for a couple of weeks at least now.
After 3 days sitting in the car park since I last used it, I came back to find that it wouldn't start... But it did crank only once very briefly when I attempted to turn the key all the way very fast, then nothing.
At first I thought it was the battery then I checked the starter and the wiring and the fuses/relays, tried pushing it and jump starting with cables attached to 2 running cars even.... nothing, no crank.
I just realised yesterday after alot of researched that the anti theft shouldn't blink when the key is turned to the on position.
So now I'm looking at my immobiliser issue here, and by the way the key unlocks and locks the car remotely. Also the steering wheel unlocks with the key.
I left the battery unpluged for a night but still.
I had an engine light coming and going a while ago P0390 for the camshaft position sensor but that shouldn't be the issue here.
Any help or ideas would be much appreciated
Thanks
02maher is offline   Reply With Quote
Old 04-28-2020, 06:39 PM   #2
p1l0t
p1l0t's Avatar
Originally Posted by 02maher View Post
Hello everyone,
Thanks
Did you try clearing said code?
Old 04-28-2020, 07:14 PM   #3
02maher
02maher's Avatar
Drives: Gt86 2013
Yes I erased the code, it didn't change anything
Old 04-28-2020, 07:21 PM   #4
p1l0t
p1l0t's Avatar
I assume you checked the battery voltage and it's over 24?
Old 04-28-2020, 07:21 PM   #5
p1l0t
p1l0t's Avatar
Err 12 haha
Old 04-28-2020, 07:43 PM   #6
02maher
02maher's Avatar
Drives: Gt86 2013
Err 14 haha
12.30 when not in use. over 14 when plugged to another battery
Old 04-28-2020, 07:47 PM   #7
p1l0t
p1l0t's Avatar
Yeah if you can't get it over 14v that battery DED. Should still be able to jump start it though.
Old 04-28-2020, 07:51 PM   #8
02maher
02maher's Avatar
Drives: Gt86 2013
Even with a low battery it should crank right? and the anti-theft light isn't supposed to flash...?
Old 04-28-2020, 07:52 PM   #9
p1l0t
p1l0t's Avatar
My car won't even try even if it's slightly low. It's a 2016 though.
Old 04-28-2020, 08:03 PM   #10
02maher
02maher's Avatar
Drives: Gt86 2013
Maybe it wouldn't try to crank true.
I can crank it when I connect a wire from the + of the battey to the starter relay, I tried this also with jumper cables at the same time connected to a running car's battery.
In this case I can only assume the immobiliser system prevents the spark plugs to ignite and/or the fuel pump to work.
Old 04-28-2020, 08:08 PM   #11
Did you change or modify anything prior to the problem?
If won't start with a boost or by pushing it then either the starer battery is completely toast or the key battery is low.
The key battery could have enough juice to pop the locks but not enough to deactivate the mobilizer.
Try changing the battery.
Spuds (04-29-2020)
Old 04-28-2020, 08:53 PM   #12
02maher
02maher's Avatar
Drives: Gt86 2013
I didn't do any modification, the key seem to have no sign of weak battery as it works fine from a distance of 10m (30ft).
I thought even a completely empty key battery could start the car. I will try to change it though.
Old 04-28-2020, 09:01 PM   #13
A low key battery can do weird and wonderful things. Worth a shot.
DarkPira7e (04-28-2020), JesseG (05-07-2020), Spuds (04-29-2020)
Old 04-28-2020, 09:43 PM   #14
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Please listen to this. It is such a simple test, hopefully it fixes it
anti-theft, flashing, immobiliser, immobilizer, nostart
Best anti-theft system? becausethexo Electronics | Audio | NAV | Infotainment 48 06-03-2021 10:23 PM
Anti Theft Function Cyau Scion FR-S / Toyota 86 GT86 General Forum 22 06-25-2013 06:58 PM
BRZ Anti Theft system Skurj BRZ First-Gen (2012+) — General Topics 15 01-21-2013 04:38 PM
WTB: Steering Wheel Lock for Anti-Theft 86 FRS Miscellaneous 0 11-06-2012 06:38 PM
Is this Anti-Theft light normal? davey90 AUSTRALIA 8 09-18-2012 02:04 AM
