Old 06-14-2013, 12:40 AM   #1
Cyau
Cyau's Avatar
Drives: UltraMarine FRS MT
Anti Theft Function
yes, I used the search function.
Sooo I was wondering if such thing exist in the FRS?
when I said anti theft, I'm talking about...
When door is locked via remote, if someone tries to open the door manually from the inside (assume they broke the window then tries to unlock the door), the alarm will go off.
I remember when I had my RX-8, I was specifically told there is no anti-theft on it, but I scared myself when I tried to unlock the door manually from the inside when I locked the door with my remote while I was inside the car.
Soooo I was wondering if there might be ANY kind of anti-theft feature that might be a "hidden" feature?
Cyau is offline   Reply With Quote
Old 06-14-2013, 12:45 AM   #2
Bt216
Bt216's Avatar
Drives: Scion frs
No it sucks.. that's why I'm afraid to buy a nice head unit.. but you can add one for 300 at the dealer
Bt216 is offline   Reply With Quote
Old 06-14-2013, 01:03 AM   #3
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
The only anti-theft device in mine is the stick and third pedal...
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
The Following 12 Users Say Thank You to sho220 For This Useful Post:
86ing (06-14-2013), bchavs (04-29-2014), Cjymiller (06-14-2013), Enraged21 (06-14-2013), gzpermadi (06-26-2013), jonbonazza (06-14-2013), Mandy (06-25-2013), meWant (06-14-2013), Soclose09 (06-14-2013), WolfsFang (06-14-2013), YamahaR86 (06-14-2013), _hollywood (06-14-2013)
Old 06-14-2013, 01:17 AM   #4
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
There is NO anti-theft on this car, my friends have opened my door plenty of times while it was locked from the inside.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 06-14-2013, 02:01 AM   #5
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Actually, the anti-theft function does exist. I have triggered it myself a few times. Open a window, lock the car with the fob, and then try to open the door from the inside. It will go off. You can even see the light blinking on the dash!
FrX is offline   Reply With Quote
Old 06-14-2013, 09:55 AM   #6
Ryuu0u
(=^・ェ・^=)
Ryuu0u's Avatar
Drives: 2013 FRS, '08 GSXR 600
I've come across a few car theft/jacking stories lately where the thief had to abandon their plan because the car was stick shift.
Ryuu0u is offline   Reply With Quote
The Following User Says Thank You to Ryuu0u For This Useful Post:
sho220 (06-19-2013)
Old 06-14-2013, 10:49 AM   #7
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
I specifically remember this happening to me with my Tiburon. I had locked it but reached in the window to pop the trunk and an alarm went off. I went from surprised to relieved as I went to get the keyfob.
I'm sure the FR-S and/or BRZ will have similar; from FRX's post it sounds like it does. Probably harder to test because you have to get the fob far enough away from the car that it doesn't authenticate you.
GeorgeJFrick is offline   Reply With Quote
Old 06-14-2013, 11:14 AM   #8
FRiSson
Drives: FR-S MT
The U.S.-spec FR-S does not have a alarm. The principal anti-theft device is a cut off related to the chip-embedded key. In addition, the key fob allows you to manually-activate the horn in an intermittent sequence. I have pocket activated it several times.
FRiSson is offline   Reply With Quote
Old 06-14-2013, 12:08 PM   #9
shiud
Drives: 6MT Asphalt FR-S
yep, you can't start the fr-s w/o the car specific chipped key. none of that hotwire jazz will start it
shiud is offline   Reply With Quote
Old 06-14-2013, 07:58 PM   #10
Barbarian
Barbarian's Avatar
Drives: Raven FR-S
There is an ignition lock to where the car will not crank without being authenticated by the chip in the key.
Barbarian is offline   Reply With Quote
Old 06-14-2013, 09:54 PM   #11
marky
marky's Avatar
Drives: 2020 BRZ tS #54
everybody needs one of this
[ame="http://www.youtube.com/watch?v=LQbHnLSasfQ"]Anti-carjacking device - YouTube[/ame]
Old 06-14-2013, 10:42 PM   #12
Bt216
Bt216's Avatar
Drives: Scion frs
Nice
Old 06-14-2013, 10:42 PM   #13
Barbarian
Barbarian's Avatar
Drives: Raven FR-S
^^^ that is awesome
Old 06-14-2013, 10:58 PM   #14
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
I use a trunk monkey. It's old tech, but works well.
[ame="http://www.youtube.com/watch?v=Ee3L9BQQ4Gs"]Trunk Monkey - YouTube[/ame]
-Justin
Justin.b is offline   Reply With Quote
The Following User Says Thank You to Justin.b For This Useful Post:
TRD-X (06-14-2013)
Form > Function SportInjected BRZ First-Gen (2012+) — General Topics 359 04-24-2013 05:20 PM
BRZ Anti Theft system Skurj BRZ First-Gen (2012+) — General Topics 15 01-21-2013 04:38 PM
WTB: Steering Wheel Lock for Anti-Theft 86 FRS Miscellaneous 0 11-06-2012 06:38 PM
Is this Anti-Theft light normal? davey90 AUSTRALIA 8 09-18-2012 02:04 AM
Roofline: Form over function. ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 15 04-24-2011 01:27 AM
