Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 09-16-2012, 10:42 PM   #1
davey90
Akina Speed Stars
davey90's Avatar
Drives: White 86 GTS Auto [CID- ***]
Send a message via Yahoo to davey90
Is this Anti-Theft light normal?
didn't want to start a new topic as it's a simple answer, but i'm just curious if something's up with my 86 or do i need a slap in the head?
for the GTS owners, The "Anti Theft" light ( i think it is, That's what it says in the manual) which is the red light with a car and a padlock hooked into it. Does it continuously flash when your engine is off, doesn't matter whether the car door is open or closed, lock or unlocked?
mine keeps flashing unless i start the engine or turn the electrics on (Push start without the pressing on the breaks). The manual says it's normal, i don't recall seeing the light continuously flash...Just want to check if I'm seeings the right way. Btw i had the battery disconnected as i was working on installing footwell lights, didn't want to drain the battery.
Manual says something about re-registering the key or something.
davey90 is offline   Reply With Quote
Old 09-16-2012, 10:45 PM   #2
70NYD
70NYD's Avatar
Drives: RX8 S1
i dont know if it is different on the 86, but that is just your factory immobilisers light, and it will flash, always, at a set rate, untill you put the key in the ignition (or in your case push the start, with or without pressing the brake)
70NYD is offline   Reply With Quote
Old 09-16-2012, 10:48 PM   #3
davey90
Akina Speed Stars
davey90's Avatar
Sweet! Cheers dude! Solved! Thought i was seeing things...
Old 09-17-2012, 06:59 PM   #4
70NYD
70NYD's Avatar
Drives: RX8 S1
Also since I have never dealt with keyless entery, it might stop flashing once the fob is inside the car itself, but this is just a complete stab in the dark from my part :p
Old 09-17-2012, 07:37 PM   #5
Nardi330
Nardi330's Avatar
Drives: 86
mine flashes all the time when engine stops with car both locked/unlocked. but i will check tonight if it flashes with the key fob inside the car.
i have the GTS.
Nardi330 is offline   Reply With Quote
Old 09-17-2012, 08:05 PM   #6
davey90
Akina Speed Stars
davey90's Avatar
i have the GTS.
i've also just noticed this morning, that once you're near your car (if you have your dome light set to 'DOOR'), when the dome light lights up, your key fob red light will continue to flash, it also keeps blinking if you're in the car and not start the engine.
Old 09-17-2012, 08:15 PM   #7
Nardi330
Nardi330's Avatar
Drives: 86
i think mine does the same.
Old 09-17-2012, 11:05 PM   #8
70NYD
70NYD's Avatar
Drives: RX8 S1
i just checked in my 8, it only stops blinking as per my 1st post (ie it blinks in OFF, and ACC position, but stops in ON and ofcourse when you start the engine)
Old 09-18-2012, 01:04 AM   #9
proficience
proficience's Avatar
Drives: Velocity Orange 86 GTS M/T
perfectly normal dude. you need a slap in the head
proficience is offline   Reply With Quote
Car Theft Concern kash BRZ First-Gen (2012+) — General Topics 63 06-16-2014 07:01 PM
Vandalism/theft of gas. TehRickster Scion FR-S / Toyota 86 GT86 General Forum 19 08-08-2012 05:16 PM
Vehicle Theft Registration NS BRZ First-Gen (2012+) — General Topics 14 07-24-2012 01:31 PM
is it necessary to change anti-roll bar? yuli8466 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-25-2012 10:58 AM
Anti-drunk drink?! O_o 4point8 Off-Topic Lounge [WARNING: NO POLITICS] 2 12-04-2011 12:24 AM
