| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#141 |
Drives: 2020 Hakone 86
Has anyone verified fitment of the TE37 saga 17x9 +42? rays site says they do but...
#142 |
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
Yokohama Advan TC III 18x9.5 +45
NO Spacers Required!
I.G. @mytoy86
#143 | |
Drives: 2018 BRZ PP WRB
I have confirmed fitment of a certain wheel on a TRD 86 but now I'm not sure if it will fit my PP BRZ. I was told offset wasn't the issue, it's barrel clearance. So do the PP Brembos provide more barrel clearance or the TRD Brembos? |
#144 | |
The TRD brembos from the factory are the same as the PP Brembos. - Andrew |
#145 |
Ah ok. Thanks for confirming. I was about to say they look the same to me lol
| The Following User Says Thank You to tcoffin014 For This Useful Post: | Racecomp Engineering (04-17-2020) |
#146 |
FYI, PP Brembo and TRD 6 pots Brembo are the same as Brembo GT Junior kit...
#147 |
Drives: 2014 GT86
gpvecchi: you are sure on that? (checking up in background, as maybe cheaper then PP retrofit). Or you wrote that about same clearance, not about same parts?
#148 |
Site Moderator
Drives: ichi 86 Project
IDK why I haven't seen this til now. Good info.
Stickied |
| The Following User Says Thank You to ichitaka05 For This Useful Post: | timurrrr (06-23-2020) |
#149 |
Drives: Crapcan
The PP Brembo's are 4 pot here.
#150 |
Sorry I meant that PP is the same of 4 pot GT Junior and TRD is 6 pot GT Junior.
| The Following User Says Thank You to gpvecchi For This Useful Post: | timurrrr (06-23-2020) |
#151 | |
Drives: 2019 BRZ Performance Package
Does anyone know if the new 17x9 +42 te37 rub? I have hks hipermax gt coil overs. And dont want to run spacers. Will be running a 245/40 re71r |
#152 |
Does anyone know if the Sparco Assetto Gara 17x7.5 et48 will clear Brembos with a spacer? Tire Rack says they won't fit, but they don't know how close it is. The Trofeo 5 in the same size fit, so I'm thinking the Gara shouldn't be far off. I don't mind running a small spacer. Should the barrel diameter on these 2 wheels be the same?
#153 |
Drives: 2016 BRZ LIMITED
Does anyone know if the 949 6UL 17X8 +40 will fit with a spacer and if so, what size?
#154 |
TRACKBREAD
What clearance do we need to the caliper to claim they fit? 3mm? 5mm?
Is minimum spoke clearance different than minimum barrel clearance? |
| Tags |
| brz, performance package, wheels |
| Finding wheels to clear brembos | jojosbrz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 11-13-2018 09:46 AM |
| Performance package Brembos | Ernest72 | Want-To-Buy Requests | 2 | 07-14-2018 09:06 AM |
| Performance Package Brembos Freezing to Wheels? | texastwurkt3am | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-23-2018 09:31 AM |
| What pads fit the Performance Package Brembos? | mistople | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 01-03-2018 06:15 PM |
