Old 07-28-2019, 02:13 PM   #57
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Found GTS G 709 on http://gtswheels.com/gallery/
According to this page on Fitment Industries, these are 18x8.0 +35 in the front
The Following User Says Thank You to timurrrr For This Useful Post:
Aluma007 (08-04-2019)
Old 07-29-2019, 03:04 PM   #58
Evan55
Drives: 06 Exige, 17 BRZ PP
My Enkei TS-V just came in. 17x8 ET45
Good news, they fit over the Brembos. (and they look amazing!)
Bad news: its by only this much. Actually less clearance than the stock wheels, which I didnt think was possible
thoughts? For track use is this not enough clearance?
Evan55 is offline   Reply With Quote
Old 07-29-2019, 03:11 PM   #59
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
If you really want this design and are comfortable running 3mm spacers on a track, just get extended ARP studs and open-ended lug nuts.
Old 07-30-2019, 12:32 PM   #60
Evan55
You can add Enkei PF01 17x8 ET35 to fits
https://www.ft86club.com/forums/show...5&postcount=54
thanks to @atomicalex
The Following User Says Thank You to Evan55 For This Useful Post:
atomicalex (07-30-2019)
Old 07-31-2019, 02:55 PM   #61
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by timurrrr View Post
The spoke looks pretty close to the caliper near the hug. How many mm do you have there?
I never measured it, but the pictures are a little more deceiving in that matter. There is actually quite a bit of clearance between the rim and caliper, certainly more than the OEM PP wheels provide. Once I get the wheels officially on, I will update.
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
timurrrr (08-03-2019)
Old 08-03-2019, 06:16 PM   #62
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by botbs View Post
Anyone know if the SA10R 18x8.5+45 would clear or not?
Never mind, it clears!
Can you please post photos by any chance?
Old 08-03-2019, 07:12 PM   #63
Guest
Drives: 2017 BRZ PP
Would you even need extended studs for such a small spacer? I was under the impression that 3mm and smaller is fine without them.
Guest is offline   Reply With Quote
Old 08-03-2019, 11:04 PM   #64
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
I dont have the wheels anymore.
Here is the old pic
http://www.ft86club.com/forums/showp...&postcount=414
botbs is offline   Reply With Quote
The Following User Says Thank You to botbs For This Useful Post:
timurrrr (08-05-2019)
Old 08-04-2019, 01:04 AM   #65
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Did you end up mounting them? Could you get pictures if so? Thank you. I'm considering the TS-V. They look really good, but yet to see them on a twin.
Will BRZ is offline   Reply With Quote
Old 08-05-2019, 12:21 PM   #66
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Noticed that we've just reached 50 black lines (i.e. no known problems) in the list, woo-hoo!
Thanks everyone who contributed and keep them coming.
Old 08-05-2019, 12:43 PM   #67
stanrc
Drives: 2017 BRZ
I have the Konig Hypergram 17x8 +40 and I would say technically they do fit. The rubber cap on the bleed valve comes incredibly close though. I put on a 3mm spacer on the front just to be safe.
stanrc is offline   Reply With Quote
Old 08-05-2019, 02:51 PM   #68
S0crates
Drives: 2017 BRZ Limited PP
Does anyone know if the Konig Rennform 18x8.0+40 will clear the brembos? The question was asked in the following thread, but no answer yet.
https://www.ft86club.com/forums/showthread.php?t=108308
S0crates is offline   Reply With Quote
Old 08-05-2019, 05:49 PM   #69
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Thanks, that's useful!
Goodwin previously said it won't fit, but now we have a better idea by how much.
Old 08-06-2019, 08:31 AM   #70
Semiihcircle
Drives: 17 BRZ
The Apex Arc-8 Wheels do fit over the Brembos but interfere with the stock suspension of PP BrZ. When mounted with 245/40r17 Bridgestone Potenza RE71Rs.
Semiihcircle is offline   Reply With Quote
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 08:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 08:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 08:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 05:15 PM
