Old 04-16-2020, 01:41 PM   #1
oldlostcory
oldlostcory's Avatar
Drives: 2013 WRB BRZ Limited
Stiff Shifter in Neutral
I'm having an issue on my brz. The car is a 2013 with 85k miles. This just started recently. When I am in neutral the shifter does not wiggle like it used to. It has gotten to the point where I can push it to the right inbetween 5/6th gear and it will kind of just stay there. I have to physically move it back to the middle. It is stiff going to first and second as well but will spring back to the middle but not like it used to.
The car goes into gear fine when I get it over to that gear.
Could it be the springs or the metal plate that's right below the shifter?
Thanks
oldlostcory is offline   Reply With Quote
Old 04-16-2020, 03:31 PM   #2
Thanks
I reckon that would be a good place to start. The plate is easy enough to adjust and those springs are not too expensive and easy to replace.
Old 04-16-2020, 03:32 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Pull the boot off and see if anything is interfering.
Shifter stiff and hangs godbiggy Engine, Exhaust, Transmission 13 07-13-2019 03:42 PM
BC Coilovers - How stiff is stiff? XxFooManDrewxX Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 09-24-2015 12:53 PM
MTEC Industries Stiff Shifter Springs for 2013-2014 BRZ & FR-S YURparts Transmission and Driveline 16 08-07-2014 11:31 AM
MT: 1st and 2nd stiff when cold Harvey Scion FR-S / Toyota 86 GT86 General Forum 7 05-27-2014 06:50 AM
Shifter sticking on neutral? Young_makaveli Engine, Exhaust, Transmission 4 04-12-2014 01:16 PM
