#239 |
Drives: 2014 MY15 86 GTS
Can you drive on stripped wheel nuts I have two stripped on a front wheel and one on the rear???
#240 | |
Drives: MY14 86 GTS Manual Velocity Orange
Have you stripped them or was it done at a shop? the wheel nuts on the twins have a lower torque setting than most cars - only 89 ft.lb. Pick up a torque wrench from Supercheap or Bunnings and a 19mm wheel nut socket. |
#241 |
From a shop, ****heads at parkland mazda.
Should I also apply anti seize to the thread? |
#242 |
#243 |
I don't use anti seize on mine.
#244 |
Drives: 1966 Mustang, 2013 FR-S
#245 |
Anyone know if you can buy brake retaining clips for the rear drum brakes, mine snapped trying to get the rotor off.
#246 | |
Drives: 2016 BRZ
Clip: 26714FJ030 Double check/seach those. I'm in the USA and see that you're in Australia, not sure if the part numbers always match up between markets but there's a good chance that they do. Hope that helps. |
| The Following User Says Thank You to Joon525 For This Useful Post: | Halo_2 (04-19-2020) |
#247 |
Thanks that helped toyota and part codes isn’t helpful, so called up a local subaru d/ship and they ordered off that part code.
#248 |
Sporadic Member
Drives: 2016 Halo FR-S M/T
@Dave-ROR or anyone else who has been able to remove the axle nut, if I could pick your brain for a quick minute:
I'm gonna assume you guys used a 6-point 32mm socket (or SAE equivalent) to remove the axle nut? A 12-point would just round off the bolt, correct? Also, can anyone tell me what happens if you attempt to remove the axle nut without removing the dimple? Last edited by KR-S; 05-21-2020 at 05:42 AM. |
#249 |
The dimple is designed as a lock...... Factory replacements can be done front and rear without removing the hub.
#250 | |
Drives: 2020 GMC Canyon Denali Diesel
And you only need to remove the axle nut in the rear if you are installing extended studs...the standard size can be replaced by just removing the rotors.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
| The Following User Says Thank You to Opie For This Useful Post: | KR-S (05-21-2020) |
#251 | ||
Sporadic Member
I'm not sure if my electric Ryobi at full power will do the trick. Will buy a 6-point later on today to see if I can get it off but otherwise might mount the wheel to the hub and take a breaker bar to it if the Ryobi isn't powerful enough. |
| The Following User Says Thank You to KR-S For This Useful Post: | Opie (05-21-2020) |
#252 |
Sporadic Member
Alright, both axle nuts are off, but for fuck's sake, the axle will not separate from my hub. Took a mallet, no luck. Does not seem to budge at all. Do I just need to use more force? Take a big chisel to it?
Sensor is off, hub bolts off, etc, unless I'm missing something really simple. Don't want to give up on this as I don't want to pay a shop to do the rears. Any suggestions? |
| flush with stock wheels. with Stud installation. | adamturbo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 43 | 12-10-2012 05:30 AM |
| Wheel stud | Guaruja | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 10-11-2012 03:42 AM |
| Lug Nut Stud | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-22-2012 11:26 PM |
| Scion FRS center wheel caps replacement? | Silverback | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 09-03-2012 03:16 AM |
| Are there any RWYB Wheel to Wheel road races? | LexusFman | Other Vehicles & General Automotive Discussions | 1 | 11-05-2011 01:28 PM |
