Old 04-11-2020, 08:51 AM   #239
Halo_2
Drives: 2014 MY15 86 GTS
Can you drive on stripped wheel nuts I have two stripped on a front wheel and one on the rear???
Halo_2 is offline   Reply With Quote
Old 04-11-2020, 09:05 AM   #240
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
with two gone on one wheel your asking for trouble IMHO. you should get them replaced ASAP.
Have you stripped them or was it done at a shop? the wheel nuts on the twins have a lower torque setting than most cars - only 89 ft.lb. Pick up a torque wrench from Supercheap or Bunnings and a 19mm wheel nut socket.
sneaky_pete is offline   Reply With Quote
Old 04-11-2020, 09:08 AM   #241
Halo_2
From a shop, ****heads at parkland mazda.
Should I also apply anti seize to the thread?
Old 04-11-2020, 09:12 AM   #242
sneaky_pete
I'd be taking it back to them and making them fix it at their cost.
they should replace the whole lot as they are likely all over torqued and probably damaged.
The torque setting is in the owners manual.
Old 04-11-2020, 09:16 AM   #243
sneaky_pete
I don't use anti seize on mine.
Old 04-12-2020, 01:28 PM   #244
Rosticles
Drives: 1966 Mustang, 2013 FR-S
It is not recommended to use anti-seize. The recommended torque is based on a non-lubricated fastener.
That being said, I do use anti-seize on mine with ~10% less torque.
Rosticles is offline   Reply With Quote
Old 04-19-2020, 07:41 AM   #245
Halo_2
Anyone know if you can buy brake retaining clips for the rear drum brakes, mine snapped trying to get the rotor off.
Old 04-19-2020, 12:02 PM   #246
Joon525
Joon525's Avatar
Drives: 2016 BRZ
*snip*
Pin: 26716FJ000
Clip: 26714FJ030
Double check/seach those.
I'm in the USA and see that you're in Australia, not sure if the part numbers always match up between markets but there's a good chance that they do.
Hope that helps.
Joon525 is offline   Reply With Quote
Old 04-19-2020, 08:57 PM   #247
Halo_2
Thanks that helped toyota and part codes isn’t helpful, so called up a local subaru d/ship and they ordered off that part code.
Old 05-21-2020, 03:58 AM   #248
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
@Dave-ROR or anyone else who has been able to remove the axle nut, if I could pick your brain for a quick minute:
I'm gonna assume you guys used a 6-point 32mm socket (or SAE equivalent) to remove the axle nut? A 12-point would just round off the bolt, correct?
Also, can anyone tell me what happens if you attempt to remove the axle nut without removing the dimple?
Old 05-21-2020, 06:40 AM   #249
Halo_2
The dimple is designed as a lock...... Factory replacements can be done front and rear without removing the hub.
Old 05-21-2020, 03:25 PM   #250
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Use a powerful electric impact...It laughs at the dimple.
And you only need to remove the axle nut in the rear if you are installing extended studs...the standard size can be replaced by just removing the rotors.
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 05-21-2020, 03:50 PM   #251
KR-S
Sporadic Member
KR-S's Avatar
Yep, installing ARP extended wheel studs using the ball joint method. Fronts are done no problem, just need to do the rears now.
I'm not sure if my electric Ryobi at full power will do the trick. Will buy a 6-point later on today to see if I can get it off but otherwise might mount the wheel to the hub and take a breaker bar to it if the Ryobi isn't powerful enough.
Old 05-23-2020, 02:50 AM   #252
KR-S
Sporadic Member
KR-S's Avatar
Alright, both axle nuts are off, but for fuck's sake, the axle will not separate from my hub. Took a mallet, no luck. Does not seem to budge at all. Do I just need to use more force? Take a big chisel to it?
Sensor is off, hub bolts off, etc, unless I'm missing something really simple. Don't want to give up on this as I don't want to pay a shop to do the rears.
Any suggestions?
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 04:30 AM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 02:42 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 10:26 PM
Scion FRS center wheel caps replacement? Silverback Cosmetic Modification (Interior/Exterior/Lighting) 10 09-03-2012 02:16 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
