| Engine Swaps Discussion of engine swaps. |
#15 |
Drives: FRS
Yes that may be an option but the engines that I am finding are from wreckers / salvage places who have already pulled the engine from the car and they can probably give me a VIN that I will have no way of verifying if it really came form a certain vehicle. If it was a private seller then that would definitely work.
#16 |
The Dictater
Drives: '13 Red Scion FRS
Doesn't each engine have an ID plate on the front?
#17 | |
BAE
Drives: Asphalt FRS
| The Following 2 Users Say Thank You to Decimus For This Useful Post: | gravitylover (09-26-2020), knucklehead (04-10-2020) |
#18 |
Drives: FRS
#19 |
BAE
Drives: Asphalt FRS
| The Following User Says Thank You to Decimus For This Useful Post: | knucklehead (04-10-2020) |
#20 |
Drives: FRS
#21 |
Drives: FRS
Is the $600 upcharge from a 2014 used engine to a 2015/2016 engine worth it to get the upgraded to the coilpacks and wiring harness? What was "upgraded" to said coilpacks and wiring harness anyways?
#22 |
Drives: FRS
Started draining the oil and coolant, removing bolts and nuts, and disconnecting wires and hoses. I couldn't remove the fuel lines as I was trying the DIY version I saw in some videos how it is done but couldn't take them off. Seems like I will have to buy the fuel disconnect tool.
My car is automatic and I would have to remove the torque converter bolts. The crank normally rotates clockwise, right? need to make sure of it as I would have to hold the crank in place when I loosen the bolts to the torque converter. I wouldn't want to rotate the crank the opposite direction since I think it would cause a problem. Last edited by knucklehead; 04-22-2020 at 08:44 AM. |
#23 |
Drives: RX-7 / BRZ
AST's Subaru fuel line disconnect tool #8028. Makes it super easy on this car, especially that line that has that hard 90 bend right before the fitting.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
| The Following User Says Thank You to Kiske For This Useful Post: | knucklehead (04-21-2020) |
#24 |
Drives: FRS
Where do you connect attach the chain to hoist the engine? I know there is a hook at the rear but I am unsure where to attach at the front portion of the engine
For the headers, can I get away with just removing the bolts where it connects to the bottom of the engine? basically just leaving it connected to the overpipe? Anyone know why for automatic vehicles the sway bar link needs to be removed (which i believe is just 1 out of 2 of the link ends)? |
#25 |
Drives: FRS
Do you or anyone know who sells this? it would be better if it would be somewhere in Canada.
#26 |
Drives: 2016 Toyota 86
While we are on this topic, why not try and swap in a 2017+ engine with the red manifold? What does it take to get the newer engines running in a 1st gen car?
#27 | |||
Drives: 2020 GMC Canyon Denali Diesel
2013-2016 are direct, plug and play, swaps. 2017 and newer have differences that make the swap more difficult.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
| The Following User Says Thank You to Opie For This Useful Post: | knucklehead (04-22-2020) |
#28 |
| Engine oil dipstick tube replacement | Alarik | Engine, Exhaust, Transmission | 2 | 01-27-2020 01:33 AM |
| Glittery engine oil after short block replacement | msaikhan | Issues | Warranty | Recalls / TSB | 17 | 08-24-2019 02:17 PM |
| Engine Replacement issue | Sloyota | Issues | Warranty | Recalls / TSB | 5 | 08-10-2019 11:38 PM |
| Has anyone here had an engine failure? Replacement cost? | Smurfette | Engine, Exhaust, Transmission | 10 | 12-02-2015 02:19 PM |
| Exedy OEM Replacement Clutch Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 **New Site** | RallySport Direct | Transmission and Driveline | 59 | 09-01-2015 12:18 PM |
