Old 04-09-2020, 07:13 PM   #15
knucklehead
Drives: FRS
Originally Posted by Decimus View Post
If you ask the seller for the VIN, you can easily identify it that way.
Yes that may be an option but the engines that I am finding are from wreckers / salvage places who have already pulled the engine from the car and they can probably give me a VIN that I will have no way of verifying if it really came form a certain vehicle. If it was a private seller then that would definitely work.
knucklehead is offline   Reply With Quote
Old 04-09-2020, 11:06 PM   #16
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Doesn't each engine have an ID plate on the front?
Old 04-09-2020, 11:12 PM   #17
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
The VIN is actually on the engine, its on a metal plaque on the passenger side of the motor
Decimus is offline   Reply With Quote
The Following 2 Users Say Thank You to Decimus For This Useful Post:
gravitylover (09-26-2020), knucklehead (04-10-2020)
Old 04-10-2020, 02:06 AM   #18
knucklehead
Drives: FRS
This is the information that I had asked and been looking for. Thanks Decimus!
Old 04-10-2020, 02:23 AM   #19
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
No problem, i recently swapped a 16 BRZ motor into my 13 FRS too so if you have any questions ill try my best to help
The Following User Says Thank You to Decimus For This Useful Post:
Old 04-10-2020, 02:29 PM   #20
knucklehead
Drives: FRS
Will do Decimus!Thanks!
Old 04-12-2020, 12:02 PM   #21
knucklehead
Drives: FRS
Is the $600 upcharge from a 2014 used engine to a 2015/2016 engine worth it to get the upgraded to the coilpacks and wiring harness? What was "upgraded" to said coilpacks and wiring harness anyways?
Old 04-19-2020, 08:49 PM   #22
knucklehead
Drives: FRS
Started draining the oil and coolant, removing bolts and nuts, and disconnecting wires and hoses. I couldn't remove the fuel lines as I was trying the DIY version I saw in some videos how it is done but couldn't take them off. Seems like I will have to buy the fuel disconnect tool.
My car is automatic and I would have to remove the torque converter bolts. The crank normally rotates clockwise, right? need to make sure of it as I would have to hold the crank in place when I loosen the bolts to the torque converter. I wouldn't want to rotate the crank the opposite direction since I think it would cause a problem.
Old 04-20-2020, 07:36 PM   #23
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
AST's Subaru fuel line disconnect tool #8028. Makes it super easy on this car, especially that line that has that hard 90 bend right before the fitting.
The Following User Says Thank You to Kiske For This Useful Post:
knucklehead (04-21-2020)
Old 04-22-2020, 01:39 AM   #24
knucklehead
Drives: FRS
Where do you connect attach the chain to hoist the engine? I know there is a hook at the rear but I am unsure where to attach at the front portion of the engine
For the headers, can I get away with just removing the bolts where it connects to the bottom of the engine? basically just leaving it connected to the overpipe?
Anyone know why for automatic vehicles the sway bar link needs to be removed (which i believe is just 1 out of 2 of the link ends)?
Old 04-22-2020, 01:42 AM   #25
knucklehead
Drives: FRS
Do you or anyone know who sells this? it would be better if it would be somewhere in Canada.
Old 04-22-2020, 09:26 AM   #26
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
While we are on this topic, why not try and swap in a 2017+ engine with the red manifold? What does it take to get the newer engines running in a 1st gen car?
Mike_ZN6 is offline   Reply With Quote
Old 04-22-2020, 02:49 PM   #27
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Subaru special tool threads into the block right next to the A/C compressor. It's basically a big steel hook. It gives you the second lifting point for the hoist.
Yes, just be sure to disconnect and remove the harnesses for the O2 & A/F
No idea why you would need to touch that at all.
2013-2016 are direct, plug and play, swaps. 2017 and newer have differences that make the swap more difficult.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
knucklehead (04-22-2020)
Old 04-22-2020, 03:23 PM   #28
Mike_ZN6
Mike_ZN6's Avatar
It is still possible though, right? What else needs to swapped, the ECU?
Engine oil dipstick tube replacement Alarik Engine, Exhaust, Transmission 2 01-27-2020 01:33 AM
Glittery engine oil after short block replacement msaikhan Issues | Warranty | Recalls / TSB 17 08-24-2019 02:17 PM
Engine Replacement issue Sloyota Issues | Warranty | Recalls / TSB 5 08-10-2019 11:38 PM
Has anyone here had an engine failure? Replacement cost? Smurfette Engine, Exhaust, Transmission 10 12-02-2015 02:19 PM
Exedy OEM Replacement Clutch Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 **New Site** RallySport Direct Transmission and Driveline 59 09-01-2015 12:18 PM
