Old 08-10-2019, 04:37 PM   #1
Sloyota
Drives: Black, slow, neckbreaking
Engine Replacement issue
Hi guys, I recently swapped my fa20 due to blowing up my first one. Everything is connected. When I try to turn it on, all I get is the starter clicking. What can it be? Thanks in advance!
Sloyota is offline   Reply With Quote
Old 08-10-2019, 05:50 PM   #2
humfrz
What can it be? A lot of things.
Maybe your car is rejecting the new engine -
I would suggest you start by having the battery load tested and charged.
humfrz
Old 08-10-2019, 05:57 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
have you checked that the other motor wasn't seized?
Old 08-10-2019, 06:27 PM   #4
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
humfrz
This. Your battery is most likely dead.
Charge it.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
Old 08-10-2019, 10:52 PM   #5
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
If the battery checks out OK then you need to check your grounds and make sure you have them connected and tightened down.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 08-10-2019, 11:38 PM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
Rip apart the block and replace the fried piston rings.
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 09:39 AM
Syncro Issue - Odds of replacement? Chronology Southern California 9 08-18-2017 11:13 AM
Wierd Electrical issue - no windows + no trunk after battery replacement Takumi788 Issues | Warranty | Recalls / TSB 7 11-11-2016 10:15 AM
If my car had an engine replacement: short block, am I still able to get a super char VeganGirl Forced Induction 2 07-20-2016 08:35 AM
Has anyone here had an engine failure? Replacement cost? Smurfette Engine, Exhaust, Transmission 10 12-02-2015 02:19 PM
