Old 08-22-2019, 10:09 PM   #1
msaikhan
Drives: frs
Glittery engine oil after short block replacement
2013 frs 125k
Long story short: engine started knocking after Valve spring recall. Oil pick up screen was clogged.
Dealer replaced short block.
~4500 miles after short block.
3 oil changes since then.
oil change at 500, 1000 then 4500miles.
This video is from the 3rd oil change. Look like i put some glitter into the oil. The other 2 oil changes was not like this, some gold flakes nothing crazy but no glitter.
Is this normal after short block replacement or am i about to get a knock on the door?
Here's Video: [ame]https://www.youtube.com/watch?v=YUQmWRtoJSY[/ame]
msaikhan is offline   Reply With Quote
Old 08-22-2019, 10:13 PM   #2
ermax
ermax's Avatar
Originally Posted by msaikhan View Post
2013 frs 125k
Here's Video:
Not normal. You have a bearing about to go. Thank that shit dealer for fucking you two times. I give it a 2 weeks to a month before it’s knocking. Surprised it isn’t already knocking.
Old 08-22-2019, 10:16 PM   #3
ermax
ermax's Avatar
Well let me confirm one thing. This pan wasn’t used to drain your oil after the first failure was it? If so this could be left over bearing material from the last failure that you just didn’t notice on your other changes post short block replacement.
Old 08-22-2019, 10:20 PM   #4
msaikhan
Drives: frs
The pan was used for the 3 oil changes after rebuild. But the 2 oil changes before wasnt sparkly like this one.
I hope it is left over material. But doubt it. And the fking dealer not going to do sh** till i tow it to them.
Old 08-22-2019, 10:22 PM   #5
ermax
ermax's Avatar
It wouldn’t be left over in the engine if that is what you are thinking (hoping). Not 2 changes later suddenly showing up. This is a new failure in the making. Sorry to hear about this.
They most likely botched the packing like they did on the recall and your pickup will be covered in packing. I would try to be around and get pics of the pickup before they clean it up and play stupid.
The Following 3 Users Say Thank You to ermax For This Useful Post:
humfrz (08-22-2019), Tcoat (08-23-2019), venturaII (08-23-2019)
Old 08-23-2019, 09:41 AM   #6
msaikhan
Drives: frs
I meant like left over material in the pan. I dont remember cleaning the pan in the last few oil changes.
Is it possible that this is just engine breaking in?
Old 08-23-2019, 10:16 AM   #7
humfrz
I have a general question:
Can the oil pan on a FA20 engine be removed without taking the engine out?
If so, what I would do is to have Bubba, up at the local automotive shop, drain the oil, change the filter, remove the oil pan, check and clean the oil pick-up screen, clean the oil pan, replace, fill with oil. Then drive the car for a few hundred miles and observe the oil for metal particles.
humfrz
Old 08-23-2019, 10:17 AM   #8
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Any recent change in how the engine sounds when running? Especially when fully warm?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 08-23-2019, 10:24 AM   #9
msaikhan
Drives: frs
engine has been running and sounding perfectly normal. No ticking or knocking.
Old 08-23-2019, 10:30 AM   #10
msaikhan
Drives: frs
humfrz
Pretty sure oil pan can be removed without taking engine out. I would do it, but i have a year of warranty on the engine and it could or might avoid warranty, or i won't be able to prove that their work caused the damage because i cleaned the clogged pickup screen etc..
The Following User Says Thank You to msaikhan For This Useful Post:
ermax (08-23-2019)
Old 08-23-2019, 11:15 AM   #11
msaikhan
Drives: frs
If i do end up taking it to dealer i will do that for sure.
I was thinking and i have fumoto drain valve, and since i don't have the drain bolt magnet to collect the sludge, so my oil looks like this? idk. I guess i'll just live with it and if it blows i'll tow it to the dealer.
Old 08-23-2019, 11:24 AM   #12
ermax
ermax's Avatar
When I was asking about your "pan" I was referring to the one in your video. My drain pan at the house has been littered with bearing from three different cars over the years. Unless you clean it really well who knows what you are looking at.
But in the post I am quoting I think you are referring to the oil pan on the car. I know the dealer screwed up on the valve recall but if they are dumb enough to put a new short block on the car and not bother to clean out the pickup and pan then wow they are on a new level of stupid.
As I said before, I suspect you are in the process of eating another bearing in your brand new short block and I would bet a lot of money that your pickup is blocked with packing.
The Following User Says Thank You to ermax For This Useful Post:
Tcoat (08-23-2019)
Old 08-23-2019, 11:26 AM   #13
ermax
ermax's Avatar
Yes you can drop the pan without pulling the engine but I agree with your logic about the warranty. Just leave it alone and hope the dealer takes care of you.
Old 08-23-2019, 11:31 AM   #14
msaikhan
Drives: frs
Well i hope they did clean the oil pan when they replaced the short block. I was directly talking with the GM of the dealer and he said he put his best guy(master tech with 30 years or smthn experience) on my engine. I also met the tech who seems to know what he was doing. I will send in oil sample to black stone and see where this goes. I'm just going to drive and enjoy the car, got autocross tomorrow.
Florida: FA20 Engine Short block ibr_adam09 Engine, Exhaust, Bolt-Ons 4 06-10-2019 01:50 AM
FS: FA20 engine short block ($1450 OBO) [SoCal] official_george Engine, Exhaust, Bolt-Ons 0 12-20-2016 12:13 AM
If my car had an engine replacement: short block, am I still able to get a super char VeganGirl Forced Induction 2 07-20-2016 08:35 AM
Engine Failure (#4 Rod Bearing + Short Block) eriktherod Issues | Warranty | Recalls / TSB 215 10-30-2015 12:24 AM
Reliability of engine with short block replaced ShadowTS Issues | Warranty | Recalls / TSB 4 08-22-2014 11:49 PM
