Old 04-01-2020, 02:23 PM   #1
cat94
Drives: '17 86
Does the car need to be level when flushing brake fluid?
This is my first time flushing brake fluid, and I only have 2 jack stands. Can I do the rear first, then the front? Or is it recommended that the car be level to the ground.
cat94 is offline   Reply With Quote
Old 04-01-2020, 02:45 PM   #2
It is a pressurized system not gravity so it does not have to be level at all.
gravitylover (04-02-2020), Sapphireho (04-01-2020), soundman98 (04-01-2020)
Old 04-01-2020, 07:54 PM   #3
cat94
Drives: '17 86
Makes sense, thanks!
Old 04-01-2020, 08:04 PM   #4
Bleed nipple needs to be the high point.
Old 04-01-2020, 08:12 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
ddevl_86 (04-09-2021), gravitylover (04-02-2020), humfrz (04-03-2020), Ultramaroon (04-01-2020)
Old 04-01-2020, 08:27 PM   #6
I disapprove.
Old 04-01-2020, 09:27 PM   #7
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
gotta get those jack stands, you really need 4. Only two is just ...
DandoX is offline   Reply With Quote
Old 04-01-2020, 09:53 PM   #8
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
you'll be fine with your 2 jack stands. Do the farthest away from the Master Cylinder first which would be the passenger rear, then Driver rear, Passenger front, driver front
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
Old 04-02-2020, 12:55 PM   #9
Ernest72
On my BRZ I bleed brakes when I switch from winters to summers and viceversa. I typically do one side at a time, so the car is angled on one side. No issues bleeding ever. Actually the brake fluid is the cleanest of all of my cars regardless of age.
Old 04-11-2020, 07:37 PM   #10
cat94
Drives: '17 86
Cool, thanks everyone
What brake fluid do you use when bleeding/flushing the clutch? MINOCIN Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 08-24-2020 12:07 PM
Brake fluid allowe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 01-16-2020 11:38 AM
Properly flushing/bleeding radiator fluid? swift996 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-30-2014 02:50 PM
Brake fluid question barabia Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-31-2013 11:08 PM
FS: Project Mu LEVEL MAX900i Front Brake Pads CSG David Brakes, Suspension, Chassis 0 01-14-2013 02:11 PM
