Old 01-16-2020, 10:38 AM   #1
allowe
allowe's Avatar
Brake fluid
Today I opened my engine bay and realized that my brake fluid is on the minimum line. (Yes i know my brakes need to be changed but I can’t do them till summer and my brake pads have a lot of life in them left) I went to Subaru to get a bottle of dot3 brake fluid and apparently, they do not have it in stock, At all. The only thing they had was motul 5.1. I looked online for the bottle and shipping is double the price of what the bottle would cost. The guy said that he can order it from Japan but that will take a while. He also told me that, I can use any dot 3 brake fluid. I want to confirm that this is the case before I top it up. So is it true that any dot3 brake fluid will work fine to top off my existing fluid ?
allowe is offline   Reply With Quote
Old 01-16-2020, 10:52 AM   #2
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
I am confused!
Why don’t you use this.
Subaru SOA868V9220 Brake Fluid - 12 fl.oz https://www.amazon.com/dp/B00I797FQS..._gziiEbYGGWYZJ
Am I missing something ?
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 01-16-2020, 10:55 AM   #3
allowe
allowe's Avatar
Originally Posted by Busybee View Post
I am confused!
That exact code is what I showed the parts guy at Subaru and its not available anywhere in my province.
Also that link is American amazon. Canadian one doesn’t have the item available.
The Following User Says Thank You to allowe For This Useful Post:
Busybee (01-16-2020)
Old 01-16-2020, 11:08 AM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
At minimum line means you have enough fluid.
Below min line: go to any auto parts store, get smallest bottle of name-brand DOT3 (or DOT4), top off fluid.
Old 01-16-2020, 11:17 AM   #5
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
I buy from Amazon UK all the time, why can't you buy from Amazon US? Stupid US laws?
PetrolioBenzina is offline   Reply With Quote
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
soundman98 (01-16-2020)
Old 01-16-2020, 11:27 AM   #6
Stomachbuzz
Drives: 2013 FRS
Weird that the dealer wouldn't have the basic brake fluid.
As stated, you have enough fluid, but maybe do a quick check that you don't have a leak. The system should not lose fluid, but the level in the reservoir should only go down slightly as the pads wear down.
The issue with the brake system is if any air enters the lines, which cannot happen if there is any fluid showing in the reservoir.
Any DOT3 or DOT4 fluid will work. Any auto parts store, or even WalMart will have plenty in stock.
Also, the fluid that the dealer did have in stock will work as well, but it's just more expensive than you need
Stomachbuzz is offline   Reply With Quote
The Following 2 Users Say Thank You to Stomachbuzz For This Useful Post:
allowe (01-17-2020), Busybee (01-16-2020)
Old 01-16-2020, 11:38 AM   #7
czechm8
520
czechm8's Avatar
Drives: Series 10 Fr-s #520
Yes, you can use the glycol based fluids. DOT 3, 4 and 5.1 interchangeably. Higher spec. has higher boiling point.
Do not use DOT 5. That is silicone based.
I switched mine over to Motul 5.1 this summer when I flushed the fluid.
czechm8 is offline   Reply With Quote
The Following 3 Users Say Thank You to czechm8 For This Useful Post:
allowe (01-17-2020), Busybee (01-16-2020), soundman98 (01-16-2020)
Brake Fluid Question... Lebby83 Tracking / Autocross / HPDE / Drifting 2 11-02-2015 10:15 AM
Brake Fluid Question... Lebby83 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-02-2015 09:01 AM
STR 660 Brake Fluid Question babykwiss Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-25-2014 12:00 AM
Brake fluid leak.. tintumz22 Issues | Warranty | Recalls / TSB 9 02-01-2013 03:20 PM
Track Day Brake Fluid Skorov AUSTRALIA 2 11-11-2012 07:10 PM
