Old 07-21-2012, 10:00 PM   #1
Calum
That Guy
Drives: 2013 asphalt FRS MT
Oil filter part number change, both #s deconstructed.
Like many I went to change my oil after a breakin period of about 1600 km, or 1000 miles. I logged on here and went looking for the filter part number and was surprised to see that the number had already changed. From what was posted it the new filter was taller but narrower then the old part number.
This got me thinking, (I know, I made sure to disconnect the smoke detectors.) about why FHI would change it. From my experience in the automotive world, normally things are changed for two reasons, cost or safety. And the latter only happens when someone finds out.
So, I picked up a new filter and kept my old filter so I could compare the differences. I used a chisel to separate the filters to avoid generating debris. What I found didn't really shock me much to be honest.
The filters look like most, no big surprises. The anti drain back gaskets feel identical except the outside diameter of course and did an excellent job of holding the old oil in when the filter was removed.
The bypass spring tensions felt identical as well. And both seem to have identical travel, though I couldn't get a pic of either with only two hands. One thing I don't like is that the oil will wash over the filter media before it reaches the bypass. So any debris caught has a much higher chance of getting put back into the system if/when the bypass opens. The other thing I don't like is how small the opening to the bypass is and even worse the outlet from it. The hole in the middle of the pic immediately above is what the oil has to flow through once the bypass opens.
When I bought the new filter I found out the torque sequences have changed. I'd attribute that to the differences in the seals. The new seal is thicker and more pliable. The old one seems very firm though I highly doubt there would be any chance of it leaking aside from being installed incorrectly. Personally I prefer the old seal, but the new seal would be more idiot proof.
Then we get to the filter media itself. The new filter has seven less pleats (63 vs 56) and the pleats are much shallower. (If you know how to read a vernier scale, go for it but I'm not explaining it over the internet. I mainly did this for illustration purposes) I must say, I'm not enthralled with the change. The filter media seems to be the same, but there's a lot less of it. This tells me they did this to save cost.
I'm going to investigate getting my hands on some of the old part number filters because this change is only going to shorten the life of the filter before media gets clogged and it starts to bypass.
One thing that did impress me was the complete lack of visible debris in the used filter.
Old 07-21-2012, 10:42 PM   #2
getbent
Drives: 2013 FR-S Blue MT
Thanks for the detailed writeup. I'd like to see how the new Wix 57830 compares.
getbent is offline   Reply With Quote
Old 07-21-2012, 11:03 PM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Very interesting. I'll be replacing my filters every oil change, so I'm not worried about capacity. Also, a filter magnet will help reduce debris making it though the bypass.
Old 07-22-2012, 12:58 AM   #4
roddy
roddy's Avatar
Drives: '13 Ultramarine
Thanks for that. I should pick up a case of the 130s when I'm near the Subi dealer on Monday.
Old 07-22-2012, 02:18 PM   #5
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by Draco-REX View Post
Very interesting. I'll be replacing my filters every oil change.
Considering the ease of changing the filter I will be changing the filter between oil changes. I don't plan on changing my oil every 3k, closer to 5-6k so I'll change my filter every 3k.
Old 07-22-2012, 03:15 PM   #6
Calum
That Guy
I'm thinking the same thing.
Old 07-24-2012, 01:05 PM   #7
Tainen
Drives: First SWP BRZ-L
Sure is a lot easier to do that with it up on top. not a bad idea.
Maybe I'll buy a 6 pack of filters off of one of the OEM parts websites.
the old ones, of course.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 07-25-2012, 12:48 AM   #8
reeves
This is great info to know! How would these OEM filters compare to aftermarket oil filters like Mobil1 or Purlator? Mobil1 seems to make quality filters.. is it even worth it to buy OEM filters now?
Old 07-25-2012, 01:04 AM   #9
ayau
Drives: Some rust bucket
i had my oil changed at a subaru dealership 2 weeks ago and they used the old style filter.
this may sound like a dumb question, but did you pick up the correct filter? did the dealer say that was the proper filter for the brz/frs?
Old 07-25-2012, 04:21 AM   #10
Calidrifter
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
It would be helpful to know where you got the filter. Seeing as at Toyota it's an extra 4-5 dollars that may have been a reason for Toyota to change part numbers.
Club 4AG | Apex'i | HKS | GrimmSpeed | TRD | Beat Sonic | ENKEI | Cusco | Fujitsubo
Originally Posted by Jyn View Post
That guy, like me after BBQ Thursdays, is full of shit.
Calidrifter is offline   Reply With Quote
Old 07-25-2012, 02:49 PM   #11
Calum
That Guy
One came on the car, the other I bought at a local sub's dealership.
Toyota didn't change the part number, Subaru did. It's a Subaru part. I'm not sure why Toyota wants s much for the filter, here it's 2.5 times more at Toyota then Subaru but its th exact same filter.
Old 07-27-2012, 01:18 PM   #12
rice_classic
Just for kicks and giggles... I used Purolator's website to cross reference vehicle applications and the Purolator Oil Filter for the 86 is the same as the one for the S2000. PL14459. However, when doing a little research over at NASIOC, apparently a Purolator rep said that the PL14460 should be used instead as it has a better drainback properties and bypass valve psi rating.
Ironically, I run the PCX-004 (JDM part#) s2000 oil filter on my CRX road race car and I think I might just use that on my FRS since I buy them in bulk and it's known to be a very very good filter.
Old 07-27-2012, 02:47 PM   #13
Calum
That Guy
Yes, it was the correct filter as specified in the TSB for the oil filter part number change.
Old 07-27-2012, 02:48 PM   #14
Calum
That Guy
I don't this is the first automotive filter I've taken apart.
Part number or name for this clip TrickyFrenchman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 07-16-2012 10:50 PM
Door Light - After the part number for this DriftEightSix Cosmetic Modification (Interior/Exterior/Lighting) 0 07-07-2012 03:49 AM
Part Number for this DriftEightSix AUSTRALIA 20 06-25-2012 08:30 PM
5AD Spoiler Part Number djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 4 06-01-2012 11:48 PM
Got my first FR-S part in today (Oil Filter) Jeff Lange Scion FR-S / Toyota 86 GT86 General Forum 5 05-05-2012 04:12 PM
