Old 03-21-2020, 07:33 AM   #29
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
If the guy is indeed a nurse and it isn't just a play for sympathy, he working so many hours he is so exhausted, he has obviously already substantially damaged his car at least once before, their combined mechanical skills can not figure out that a "bent" rear wheel means more than an alignment and there are no "tie rods" on the rear and they think they can bandage this all together then I think he should be looking for alternative transportation for the duration of this situation!
I think his lack of mechanical knowledge is making him call the rear toe link a tie rod.
I'm a mechanic, my job is open, napa, carquest and best buy are still open (only open B2B on deliveries and drivers leave parts outside the door) and I just rebuilt the bearing plates for the alignment rack yesterday, were probably not the only shop in this situation, but bro wants to figure it out himself, which I think the current context makes harder.
If it needs fixing quick, bring it to a pro.
The Following User Says Thank You to RZNT4R For This Useful Post:
Tcoat (03-21-2020)
Old 03-21-2020, 10:31 AM   #30
soundman98
ProCrastinationConsultant
soundman98's Avatar
as they say, "you can have it cheap, fast, or right. pick 1."
Tcoat (03-21-2020)
Old 03-21-2020, 04:24 PM   #31
alan.chalkley
Drives: 4wd zooks
stock up on baling wire and duct tape!
Here down under we use tree branches and duct tape , for the outback bush temporary repairs , until we limp it back into town.
alan.chalkley is offline   Reply With Quote
The Following User Says Thank You to alan.chalkley For This Useful Post:
soundman98 (03-21-2020)
Need to replace bent OEM '13 wheel. Best option? LudwigMiles Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2017 11:27 PM
PSA: Don't drive like me (unless you want a bent wheel) mav1178 Tracking / Autocross / HPDE / Drifting 11 07-25-2015 03:37 PM
Really bent wheel or a repair rip off? joshlx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 02-17-2014 01:04 PM
New Wheels Bent Admired Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 39 10-20-2013 09:39 PM
Bent Rim Sir Alex Mid-Atlantic 5 08-09-2013 03:34 PM
