Old 03-20-2020, 02:19 PM   #15
FinallyGot
Drives: Brz
Well, that's a shame your friends car got smacked.
I would suggest it be taken in for an alignment. The alignment shop will be able to tell what is needed to be replaced to make the wheel straight.
Then you can worry about the wheel bearings and other wheel parts being whacked out.
Forsure, Trying to get this job done asap. With the coronavirus goin on he's having trouble getting around town etc. Took apart everything with the alignment shop and found out the tie rod and more were bent too.
Any other areas I should take apart and check?
FinallyGot is offline   Reply With Quote
The Following User Says Thank You to FinallyGot For This Useful Post:
humfrz (03-20-2020)
Old 03-20-2020, 02:41 PM   #16
Well, about a year ago, I whacked mrs humfrz's Saturn hard, broadside against a curb (NO, I don't wanna talk about how it happened - ), and it needed a front strut, front spindle, front wheel bearing, front LCA, front wheel rim and a rear wheel bearing.
So, once the alignment is set so it will drive straight, a road test should show if anything is whacked out.
Old 03-20-2020, 02:54 PM   #17
FinallyGot
Drives: Brz
Dang thats crazy did u have to replace airbags?
humfrz (03-20-2020)
Old 03-20-2020, 02:59 PM   #18
He shouldn't be trying to get around town anyway. That is the whole idea of the lockdowns.
soundman98 (03-20-2020)
Old 03-20-2020, 03:14 PM   #19
Well, no. I drifted broadside on a snow covered street, into the curb. I was showing off to mrs humfrz how the nannies could pull a car out of sudden turn on slick roads. Well, she was NOT impressed -
humfrz -
Old 03-20-2020, 03:36 PM   #20
FinallyGot
Drives: Brz
Not when you're a nurse bro. His hours are crazy right now.
The Following 2 Users Say Thank You to FinallyGot For This Useful Post:
humfrz (03-20-2020), Tcoat (03-20-2020)
Old 03-20-2020, 09:23 PM   #21
Well then should be driving back and forth not "getting around town,etc" as stated.
x808drifter (03-21-2020)
Old 03-21-2020, 12:14 AM   #22
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
He is a vague story Bro. Move on. He will or will not figure it out Bro.
Old 03-21-2020, 12:23 AM   #23
soundman98
ProCrastinationConsultant
soundman98's Avatar
dude. bro. dude.
Old 03-21-2020, 12:49 AM   #24
hey, bro, maybe the dudes nursing stations are at different locations. like, you know, like, it could be, right ... bro
Old 03-21-2020, 02:22 AM   #25
If the guy is indeed a nurse and it isn't just a play for sympathy, he working so many hours he is so exhausted, he has obviously already substantially damaged his car at least once before, their combined mechanical skills can not figure out that a "bent" rear wheel means more than an alignment and there are no "tie rods" on the rear and they think they can bandage this all together then I think he should be looking for alternative transportation for the duration of this situation!
Halo_2 (03-21-2020), humfrz (03-21-2020), soundman98 (03-21-2020), x808drifter (03-21-2020)
Old 03-21-2020, 03:03 AM   #26
Wha'd I miss, bro?
Old 03-21-2020, 03:08 AM   #27
Wha'd I miss, bro?
humfrz (03-21-2020), ls1ac (03-21-2020), soundman98 (03-21-2020), Ultramaroon (03-21-2020)
Old 03-21-2020, 03:35 AM   #28
Well, I'll agree that the OP's buddy should take his car into a shop and rent a car until his is fixed.
Need to replace bent OEM '13 wheel. Best option? LudwigMiles Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2017 11:27 PM
PSA: Don't drive like me (unless you want a bent wheel) mav1178 Tracking / Autocross / HPDE / Drifting 11 07-25-2015 03:37 PM
Really bent wheel or a repair rip off? joshlx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 02-17-2014 01:04 PM
New Wheels Bent Admired Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 39 10-20-2013 09:39 PM
Bent Rim Sir Alex Mid-Atlantic 5 08-09-2013 03:34 PM
