Old 03-19-2020, 06:56 PM   #1
FinallyGot
Drives: Brz
Bent wheel
So my friends frs just got smacked, Right now we're in the process of doing body work ourselves but the rear wheel is bent inward. I was wondering if a simple alignment could fix this issue or is the Rear control arm bent and pretty much needs to be repaired? Is there any temporary fix for this? The wheel is bent inward at a decent angle
FinallyGot is offline   Reply With Quote
Old 03-19-2020, 06:59 PM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Take everything apart, inspect, and replace all parts that are not as they should be.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
Impureclient (03-19-2020), Mr.ac (03-19-2020), soundman98 (03-19-2020)
Old 03-19-2020, 07:19 PM   #3
Decep
Drives: 2013 FR-S Series 10
seriously? temporary fix for bent wheel and or suspension components?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 03-19-2020, 07:19 PM   #4
FinallyGot
Drives: Brz
My bad I dont work on cars besides fixing body panels and paint, Chill out.
Old 03-19-2020, 07:21 PM   #5
FinallyGot
Drives: Brz
As far as I can tell the LCA is bent, How much should I be paying for new ones?
Old 03-19-2020, 07:24 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
stock up on baling wire and duct tape!
Old 03-19-2020, 08:41 PM   #7
Impureclient
Drives: 2015 FR-S
And Popsicle sticks, they are great little braces.
Impureclient is offline   Reply With Quote
The Following User Says Thank You to Impureclient For This Useful Post:
Old 03-19-2020, 08:56 PM   #8
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
As far as I can tell ...
You may think me cold and unfeeling, but that's not good enough.
Know exactly what parts you need, measure parts from bolt-to-bolt on the good side, compare with bad side.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
ActionMaxon (03-20-2020), soundman98 (03-19-2020)
Old 03-19-2020, 09:12 PM   #9
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Of better yet, you are a body guy. Take it to a suspension guy.
Mr.ac (03-19-2020), RToyo86 (03-19-2020), soundman98 (03-19-2020)
Old 03-19-2020, 10:51 PM   #10
humfrz
Well, that's a shame your friends car got smacked.
I would suggest it be taken in for an alignment. The alignment shop will be able to tell what is needed to be replaced to make the wheel straight.
Then you can worry about the wheel bearings and other wheel parts being whacked out.
humfrz
FinallyGot (03-20-2020)
Old 03-19-2020, 10:58 PM   #11
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Detailed pictures of the suspension damage would help here.
Will BRZ is offline   Reply With Quote
Old 03-20-2020, 12:01 AM   #12
soundman98
soundman98's Avatar
i've heard bungie cords and ratchet straps work great too!
in fact, i've read more than a few stories of 4x4's with busted front knuckles making it out of the forest with nothing more than a log and a ratchet strap holding the wheel to the truck.
Old 03-20-2020, 08:00 AM   #13
Don't get snippy.
Boomerang (03-20-2020), NoHaveMSG (03-20-2020), soundman98 (03-20-2020), x808drifter (03-21-2020)
Old 03-20-2020, 09:50 AM   #14
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
I have a used one, removed to install upgraded LCA's...
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
Tcoat (03-20-2020)
Need to replace bent OEM '13 wheel. Best option? LudwigMiles Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2017 11:27 PM
PSA: Don't drive like me (unless you want a bent wheel) mav1178 Tracking / Autocross / HPDE / Drifting 11 07-25-2015 03:37 PM
Really bent wheel or a repair rip off? joshlx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 02-17-2014 01:04 PM
New Wheels Bent Admired Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 39 10-20-2013 09:39 PM
Bent Rim Sir Alex Mid-Atlantic 5 08-09-2013 03:34 PM
