Old 03-19-2020, 08:51 PM   #15
daniloneil8
Originally Posted by radroach View Post
My 2nd bearing went bad by ~105k miles too, was making all the symptomatic sounds of failure- shh shh shh sounds at idle and goose-honk sounds occasionally. I had the dealership recall done last summer and they put in a fresh bearing, the updated part, at no extra charge.
Where is updated part?
daniloneil8 is offline   Reply With Quote
Old 03-19-2020, 09:11 PM   #16
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
CAUTION:
Do not enter these search words into Google Images: 'pulling a tranny'
Also caution against these search words as well: 'pulling the tranny'
ToySub1946 is offline   Reply With Quote
The Following 4 Users Say Thank You to ToySub1946 For This Useful Post:
Dave-ROR (03-19-2020), extrashaky (03-20-2020), gravitylover (03-20-2020), soundman98 (03-19-2020)
Old 03-19-2020, 09:13 PM   #17
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Originally Posted by daniloneil8 View Post
Can you post a guide to do this repair?
I can't find it myself
YouTube it. There are a few good videos out there.
To make things way easier you'll need these:
SUV jack stands. These are just taller jack stands so you can move around underneath with ease.
High lift jack or thick wood blocks to give you that 3-4" you need.
Tranny jack. Makes things easier if you can't bench press 100lbs.
Cheater bar or beaker bar. Some bolts need some "tough love"
PB blaster or any liquid bolt loosener spray.
Extra long box end wrenches. Just so you can remove the drive shaft from the diff. Those bolts where the only bolts that give me problems.
A buddy or two.
Beer and food.
I did it in my garage with a bad back. Took me about 3 days only because I only worked on it 3-4 hours at a time. No air tools just old fashioned hand tools.
As much as you think of leaving the tranny fluid in there, just drain it. You'll make a mess when you try to remove it.
It's pretty easy, given you know your way around an oil change.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
gravitylover (03-20-2020), humfrz (03-19-2020)
Old 03-19-2020, 09:29 PM   #18
ToySub1946
ToySub1946's Avatar
Lots of help here:
https://www.ft86club.com/forums/showthread.php?t=138152
Also note: best to also replace 'bearing retainer' aka quill, snout as well as replacing throwout bearing with revised one, as well as the new type grease supplied.
Additionally have clutch release fork and fork support checked for wear issues.
See pics of newer throwout bearing here:
https://www.ft86club.com/forums/showthread.php?t=129260
I believe newer style grease is supplied/packaged with new style throw out bearing.
>>>We have a new order here to shelter in place beginning midnight...allows going for food, outdoor exercise, Doctor visits, etc. Does not allow me to go buy a new car...<<<
Old 03-19-2020, 09:58 PM   #19
well now, @Mr.ac , that was a right helpful post.
(you feeling OK?)
Old 03-19-2020, 10:58 PM   #20
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
(you feeling OK?)
For now I guess. I was partying it up with some Asian dudes, they said something about being stuck inside for weeks but now it was time to party. Good times.
P.S.
you got some toilet paper to spare?
The Following User Says Thank You to Mr.ac For This Useful Post:
humfrz (03-20-2020)
Old 03-20-2020, 12:03 AM   #21
P.S.
No, but I do have an old phone book I would be willing to share -
Mr.ac (03-20-2020), ToySub1946 (03-20-2020)
Old 03-20-2020, 03:08 AM   #22
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by Griffin_Hay View Post
As far as I know there was no clutch replacements in the first 54k miles
So does it mean that your driving technique needs some looking at? Are you too heavy with clutch?
Old 03-20-2020, 10:54 AM   #23
extrashaky
Drives: 2014 BRZ Limited
My TOB went out about 13K miles ago at 97K. I read through the DIY and said, "Huh, that's not bad, I can do that."
Then I promptly got on the phone to get quotes for other people to do it instead and took it to a shop down the street.
As for your original question, it's not normal for it to go out that soon, but we also don't know how you drive. Clutch wear is dependent in large part on your technique and how many bad habits you have.
The Following User Says Thank You to extrashaky For This Useful Post:
Tcoat (03-20-2020)
Old 03-20-2020, 08:28 PM   #24
gravitylover
OP - Have you had the recall work done yet? They can replace the TOB in 5 minutes while the motor is out. If the clutch isn't shot and that's all you need that would be the way to get it done.
advice, brz, clutch, frs, help please
Clutch oem 15k miles Stevenduarte210 Transmission and Driveline 1 08-14-2019 04:14 AM
Should I replace the clutch at 38k miles? Abaier Engine, Exhaust, Transmission 23 07-09-2019 03:51 PM
700 Miles Blown Clutch Bonburner Issues | Warranty | Recalls / TSB 76 09-23-2012 09:32 PM
