Old 03-19-2020, 11:30 AM   #1
Griffin_Hay
Griffin_Hay's Avatar
Unhappy My second clutch in 110,000 miles is about to go out
I bought my 2013 FRS at 54,000 miles and around 70,000 miles my first clutch went out. now at 110,000 miles my second clutch is about to go out. Is this normal in these cars or is there something I can do to prevent further damage? Any advice is much appreciated.
Griffin_Hay is offline   Reply With Quote
Old 03-19-2020, 11:35 AM   #2
Is it the clutch failing or the throw out bearing melting down and taking the clutch with it? There is a known issue with the TOBs in these cars and if they just replaced your first one with the same old part number then it would indeed only last so long.
Under stock power there is no real recorded history of clutch failures on these cars so beyond the TOB issue it is not "normal" at all to go through clutches that quickly.
NWFRS (03-19-2020), SmaxxSmith (03-20-2020)
Old 03-19-2020, 11:46 AM   #3
humfrz
Welcome to our happy group -
As Tcoat mentioned, your clutch problems may be attributed a faulty TOB.
What makes you feel your clutch is about to go out again?
I would suggest that you have the clutch disk, pressure plate and TOB replaced. Make sure they use the NEW, improved TOB. Also, resurface the flywheel if necessary.
Barring abuse or giant power mods, that should last you another 75,000 miles.
humfrz
Old 03-19-2020, 11:53 AM   #4
Griffin_Hay
It is my throw out bearing. I can hear a chirping and slight grinding noise when I'm engaging first gear. Can I just replace the bearing and save the clutch?
Old 03-19-2020, 11:59 AM   #5
Yes. If you get to it in time. If it is still just noisy the rest of the clutch will be fine. If you wait until it fails and takes the clutch with it.
Make sure they use the new part number listed on the linked TSB
http://www.ft86club.com/forums/showthread.php?t=117440
Old 03-19-2020, 01:21 PM   #6
Griffin_Hay
Thanks for the help. Is this something I could fix on my own or should I take it to a shop to fix it. I have minor experience working on this kind of stuff
The Following User Says Thank You to Griffin_Hay For This Useful Post:
humfrz (03-19-2020)
Old 03-19-2020, 01:23 PM   #7
Involves pulling the tranny. Not a horrible task if you have the tools and resources. Loads of DIY info here for it.
Old 03-19-2020, 02:10 PM   #8
radroach
Drives: car
My 2nd bearing went bad by ~105k miles too, was making all the symptomatic sounds of failure- shh shh shh sounds at idle and goose-honk sounds occasionally. I had the dealership recall done last summer and they put in a fresh bearing, the updated part, at no extra charge.
Old 03-19-2020, 02:11 PM   #9
Impureclient
Drives: 2015 FR-S
Trade in for an automatic.
But for real though, the manual transmission must be a third of the problems in here.
Impureclient is offline   Reply With Quote
Old 03-19-2020, 02:19 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
Did it have clutch changes during its 54k period?
Old 03-19-2020, 02:21 PM   #11
Not even close. They don't take huge power well and the TOBs are bad in some.
The hard shift complaints are more just people used to the sloppy FWD systems than an issue and no doubt many of the other complaints are just people beating the crap out of them.
ElijahF (03-19-2020), HKz (03-19-2020)
Old 03-19-2020, 02:42 PM   #12
humfrz
If this car is required for every day use, I'd suggest you take it into a shop.
If you do, ask them to evaluate what parts they would suggest be replaced. Make sure they understand to use the NEW TOB part.
If you have the time and tools and work space, you may consider doing it yourself.
humfrz
Old 03-19-2020, 07:15 PM   #13
Griffin_Hay
As far as I know there was no clutch replacements in the first 54k miles
Old 03-19-2020, 08:50 PM   #14
daniloneil8
Can you post a guide to do this repair?
I can't find it myself
daniloneil8 is offline   Reply With Quote
advice, brz, clutch, frs, help please
Clutch oem 15k miles Stevenduarte210 Transmission and Driveline 1 08-14-2019 04:14 AM
Should I replace the clutch at 38k miles? Abaier Engine, Exhaust, Transmission 23 07-09-2019 03:51 PM
700 Miles Blown Clutch Bonburner Issues | Warranty | Recalls / TSB 76 09-23-2012 09:32 PM
