I bought my 2013 FRS at 54,000 miles and around 70,000 miles my first clutch went out. now at 110,000 miles my second clutch is about to go out. Is this normal in these cars or is there something I can do to prevent further damage? Any advice is much appreciated.
#2 | |
Under stock power there is no real recorded history of clutch failures on these cars so beyond the TOB issue it is not "normal" at all to go through clutches that quickly.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | NWFRS (03-19-2020), SmaxxSmith (03-20-2020) |
#3 | |
![]() As Tcoat mentioned, your clutch problems may be attributed a faulty TOB. What makes you feel your clutch is about to go out again? I would suggest that you have the clutch disk, pressure plate and TOB replaced. Make sure they use the NEW, improved TOB. Also, resurface the flywheel if necessary. Barring abuse or giant power mods, that should last you another 75,000 miles. humfrz |
#4 |
It is my throw out bearing. I can hear a chirping and slight grinding noise when I'm engaging first gear. Can I just replace the bearing and save the clutch?
#5 | |
Make sure they use the new part number listed on the linked TSB http://www.ft86club.com/forums/showthread.php?t=117440
#6 |
Thanks for the help. Is this something I could fix on my own or should I take it to a shop to fix it. I have minor experience working on this kind of stuff
| The Following User Says Thank You to Griffin_Hay For This Useful Post: | humfrz (03-19-2020) |
#7 |
Involves pulling the tranny. Not a horrible task if you have the tools and resources. Loads of DIY info here for it.
#8 |
Drives: car
My 2nd bearing went bad by ~105k miles too, was making all the symptomatic sounds of failure- shh shh shh sounds at idle and goose-honk sounds occasionally. I had the dealership recall done last summer and they put in a fresh bearing, the updated part, at no extra charge.
#9 |
Drives: 2015 FR-S
#10 | |
Drives: Subaru BRZ
#11 | |
The hard shift complaints are more just people used to the sloppy FWD systems than an issue and no doubt many of the other complaints are just people beating the crap out of them.
#12 | |
If you do, ask them to evaluate what parts they would suggest be replaced. Make sure they understand to use the NEW TOB part. If you have the time and tools and work space, you may consider doing it yourself. humfrz |
#13 |
#14 |
| Tags |
| advice, brz, clutch, frs, help please |
| Clutch oem 15k miles | Stevenduarte210 | Transmission and Driveline | 1 | 08-14-2019 04:14 AM |
| Should I replace the clutch at 38k miles? | Abaier | Engine, Exhaust, Transmission | 23 | 07-09-2019 03:51 PM |
| 700 Miles Blown Clutch | Bonburner | Issues | Warranty | Recalls / TSB | 76 | 09-23-2012 09:32 PM |
