Old 03-07-2020, 06:12 PM   #1
sroby
Drives: 2015 Firestorm 08/05/15
Gear indicator not registering 5 th gear on 6mt
I need more brain horsepower for this one, all of a sudden coming back from a mtn run I noticed anytime I go into 5 th gear the gear indicator led doesn't register 5th. All other gears read out as advertised. 1-4 ok no 5 then 6 ok.
Intermittently while rolling in 5 th gear it will finally come on but will indicate 4 th. Does anybody know where the gear indicator gets its input from. I don’t know if its from a mag pickup on transmission or wheel speed ring
This Is a 2015. I did do the y58 2018 diff swap. But it’s be indicating fine
Just want know if any body else had had an issue like this. I turned everything off on dash . I.E. shift buzzer and indicator. Disconnected battery relearned my fuel curves throttle position then turned it back on per manual. Same thing.
Thx in advance. Steve
sroby is offline   Reply With Quote
Old 03-07-2020, 06:33 PM   #2
Hi, Steve. The gear indicator is calculated as a function involving the ratio of the wheel speed to the engine speed. Is the y58 shorter than stock?
Old 03-07-2020, 06:42 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
Yes, as Ultramaroon wrote, it's calculated in ecu tune, and can be adjusted via most ecu tuning solutions for this platform (with exception of piggyback chips, which on the other hand rarely get used for these cars) there to work with different ratio FD. I hate this implementation though, as due how it is made, it feels very laggy.
Old 03-07-2020, 07:28 PM   #4
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
I have a 2014 with a y58 diff swap and it did the exact same thing. Completely normal.
MCTeeJ is offline   Reply With Quote
Old 03-07-2020, 07:50 PM   #5
norcalpb
norcalpb's Avatar
I had the same question a while ago.
https://www.ft86club.com/forums/showthread.php?t=136569
Old 03-07-2020, 11:15 PM   #6
sroby
Thanks norcalpb
Thx partner valuable info for me I really appreciate it. As a side note we’re you able to get your accurately calibrated. I also have Ecutek. I thought the tune and all other perimeters were locked per your master Ecutek tuner.
Old 03-07-2020, 11:25 PM   #7
sroby
Thx ultra
Yesir partner, stock is 4.1. Y58 dif is 4.3. My lack of knowledge, I thought the Ecutek was tune and it’s perimeters we’re all locked via your Ecutek tuner In my case Delicious. So as I’m understanding this Without having you go through delicious I should be able to go into those perimeters and make the adjustments.
Now if I can just get one of our wizards that smarter than me to give a small tutorial my life will be complete. I’m old and my pentium 2 processor of a brain just doesn’t work as fast as it used to, too much cross firing.
I do appreciate the help as always from the group.
Old 03-07-2020, 11:34 PM   #8
norcalpb
norcalpb's Avatar
No problem, I know how annoying it is to have a glitch in your HUD. This accurately calibrated the HUD. I have open flash tablet so I am unfamiliar with Ecutek.
To modify the tune you'll need to download RomRaider and have 2 files handy called .xml and .bin I believe. Do you have access to those 2 files? With Ecutek you probably need the Canbus cable too..
Old 03-08-2020, 06:14 AM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
If your current tune is by Delicious, most probably you'll need to go adjusting gear indicator calculation through them and then flash adjusted one, as i guess that your current tune is using ecutek and locked.
Old 03-08-2020, 11:54 AM   #10
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
I run 4.56 gears and have learned to happily ignore the gear indicator!
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 03-08-2020, 11:59 AM   #11
sroby
I’m going to check it out now. I’ll see if it will let me in. If not I’ll send a message to Bill at delicious Thanks again bud
Old 03-08-2020, 12:37 PM   #12
tomm.brz
Drives: brz 2017 hksv2
you can t modify it yourself
it s locked by Delicious
you need to email them and tell to modify the tables for gear indication calculation for the new fd
Old 03-08-2020, 08:03 PM   #13
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
It'll be locked. Email Delicious and explain the situation to have them update the proper tables and send you a revised tune to flash.
Jyn is offline   Reply With Quote
Old 03-08-2020, 11:34 PM   #14
Brings the thought to mind as to why anyone driving a car with a MT would need an indicator to tell what gear the car is in? -
Gear indicator (G-on) shows 2 when in 3rd gear c8Face BRZ First-Gen (2012+) — General Topics 31 07-07-2017 07:23 PM
BRZ HUD Gear Indicator Missing? norcalpb BRZ First-Gen (2012+) — General Topics 25 06-15-2015 06:55 AM
MT gear indicator WolfsFang Scion FR-S / Toyota 86 GT86 General Forum 19 07-02-2012 10:20 PM
MT Gear Indicator Issue civicdrivr Scion FR-S / Toyota 86 GT86 General Forum 28 05-21-2012 11:40 PM
Gear indicator Slick CANADA 18 05-20-2012 10:14 AM
