Old 03-02-2020, 06:32 AM   #1
PunchCake
Drives: Stock 2015 base toyota 86
I redlined my gt86 on startup
I accidentally redlined my car when it was cold but the thing is that I did it on startup I mistaken the gas pedal with the break
Did I do and damage to the engine? It doesn't make any strange noises it looks fine to me
PunchCake is offline   Reply With Quote
The Following User Says Thank You to PunchCake For This Useful Post:
humfrz (03-02-2020)
Old 03-02-2020, 06:44 AM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
Fucked it up... Wait a minute, you say "it doesn't make any strange noises.." that's really bad as in normal mode it sounds like a tractor...
The Following 5 Users Say Thank You to JD001 For This Useful Post:
Cheeky (03-05-2020), ElijahF (03-04-2020), JesseG (03-03-2020), soundman98 (03-02-2020), Tcoat (03-02-2020)
Old 03-02-2020, 06:51 AM   #3
Windycitystig
Drives:
Should be fine since it was only one time.
Windycitystig is offline   Reply With Quote
Old 03-02-2020, 07:01 AM   #4
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Wouldn't sweat it. No load, only over a few seconds, if anything important was to break you would know by now.
What's weird, however, it that the engine should not start when you're cranking with the throttle fully depressed. Did you have the throttle pedal on the floor?
alex87f is offline   Reply With Quote
Old 03-02-2020, 08:14 AM   #5
PunchCake
Yes all the way, full throttle
Old 03-02-2020, 08:19 AM   #6
Redline is as far as the car can go before the fuel cut off kicks in. It is not the engine explosion mark. The engine can rev much higher without damage.
Starting and hitting redline is not a problem unless you are at temperatures well below freezing. I highly doubt the temperatures there are that low. Even then one redline rev won't likely hurt a thing.
It is fine the engine is not made out of glass so stop worrying about it.
Dadhawk (03-02-2020), p1l0t (03-02-2020), soundman98 (03-02-2020)
Old 03-02-2020, 12:08 PM   #7
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Just don’t make that mistake when you’re in gear. Then you’ll cause some real damage.
Will BRZ is offline   Reply With Quote
Old 03-02-2020, 12:11 PM   #8
Welcome to the forum, PunchCake -
As others have said, don't worry about it - just don't do that no more -
korhun (03-02-2020), p1l0t (03-02-2020)
Old 03-02-2020, 08:58 PM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
i just did. because i was hangry and people didn't want to let me out of a parking spot. when in doubt, make yourself the craziest in the parking lot.
Old 03-02-2020, 10:02 PM   #10
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sorry you messed up big time.
I would start looking for another new engine or car for that matter.
It's fine.
Don't make a habit of it. That's all.
If you are worried about go to any dealership or mechanic, tell them what you did and be prepared to see two outcomes.
1. They would laugh at you.
2. They will rape your wallet, just to make sure you didn't hurt anything.
Old 03-03-2020, 01:08 AM   #11
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
If it's not TOTALED....
surely it will BUFF OUT...
ToySub1946 is offline   Reply With Quote
Old 03-03-2020, 11:21 PM   #12
arxm
Drives: 2013 FR-S, 2023 BRZ
if you didnt immediately break something theres a 99.9999% chance its fine, dont overthink it
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Redlined calidus BRZ First-Gen (2012+) — General Topics 16 07-22-2021 06:51 PM
HID Dim/flicker on startup Wpomp Cosmetic Modification (Interior/Exterior/Lighting) 2 01-21-2016 11:28 PM
Stall on startup? Mhenderson Software Tuning 3 06-28-2014 04:27 PM
Knocking on Startup? 636 Issues | Warranty | Recalls / TSB 17 02-03-2014 07:18 AM
long startup!!! HELP! juanam0909 Issues | Warranty | Recalls / TSB 11 05-18-2013 08:17 PM
