Old 02-19-2020, 04:27 PM   #15
Interflop
Drives: 2013 Subaru BRZ
Originally Posted by JIM THEO View Post
3" Berk catted - custom resonated front pipe, hope it will remove any rasp/rattle - as in your case - due to OEM catback:
That looks awesome! I wonder if this could in theory be done to any front pipe?
Interflop is offline   Reply With Quote
Old 02-20-2020, 02:17 AM   #16
JIM THEO
Drives: BRZ 2018
Originally Posted by tehShirt View Post
Where did you get that resonator?
Custom made by a local exhaust shop for 60 euros, not bad as I have Tomei headers+over pipe and OEM catback which, due to different size, usually creates rasp/rattle when fitted w/free flowing front pipe!
@Interflop yes it could be fitted to any FP
JIM THEO is offline   Reply With Quote
Old 02-20-2020, 10:12 AM   #17
jflogerzi
jflogerzi's Avatar
This is a vibrant ultra low noise resonator added to the stock FP and removed the stock tiny one.
2013 Series 10 FRS #553
Old 02-20-2020, 10:21 AM   #18
JIM THEO
Drives: BRZ 2018
jflogerzi what difference the new resonator made to the exhaust note and the overall sound, you have EL headers that usually create more rasp right?
Old 02-20-2020, 05:50 PM   #19
Ernest72
My old hooker black heart midpipe that was catted started to rattle and eventually it was the cat that came loose. Replaced with jdl catted and fine now. Could be the cat. Sometimes the welds break.
Old 02-20-2020, 11:07 PM   #20
jflogerzi
jflogerzi's Avatar
Sadly I replaced my loud ass tomie UEL with the JDL 4-2-1 and resonator at the same time. Here is a video of my car on the Dyno. There is no rasp in my mind.
https://photos.app.goo.gl/Ve2kv6ty2A9NWhST6
Old 02-23-2020, 07:16 PM   #21
MWines
Drives: 2019 86 GT
I have that exact same rattle, kind of like a metal rattle snake rattling its tail, on my jdl 4-2-1 el headers I installed last night. I figured it was a leak as well but just torqued everything back down after a few heat cycles today. Rattle stayed, so I feel like you guys might be right.
I have stock exhaust except for the headers. Guess I'll just live with it until I feel like swapping exhausts. Thanks for putting my heart at ease
MWines is offline   Reply With Quote
Old 02-24-2020, 08:39 AM   #22
Interflop
Yea sounds like it's not really a "problem", you just have to find the front pipe setup that works for you.
Old 03-04-2020, 01:06 PM   #23
Khánh
Khánh's Avatar
Drives: sc00ter
Originally Posted by jflogerzi View Post
I have a similar sound with my catless EL 4--2-1 headers. They are coated. It happens in a small window around 3k till 3800. Bit more purnocued when the car is cold. When the car is warm I mostly can't hear it. I have a stock OP, modified OE FP with cat and switched resonator by vibrant and a mxp sp CB. Car is very quiet and the wine from the SC is very noticeable.
why did u switch the oe front pipe resonator with Vibrant? any noticeable sound difference between the 2? how much was it to do it?
thanks
Khánh is offline   Reply With Quote
Old 03-05-2020, 11:07 PM   #24
jflogerzi
jflogerzi's Avatar
thanks
Trying to keep noise down as best I can due to SC and catless headers. 80$ for the resonator and I think it was 40-50$ to weld it in.
Old 03-11-2020, 03:57 AM   #25
ZZJ
ZZJ's Avatar
Drives: 2017 Toyota 86
I had the same header and it was raspy with all the exhaust setup I've tried.
It could be many things but I would blame uel because all the rasp went away after I changed it to EL.
ZZJ is offline   Reply With Quote
Old 06-16-2020, 01:30 PM   #26
Interflop
Just wanted to update on this.
So I went from the JDL Catted UEL to the JDL Catless UEL and the noise became worse. What it came down to was the the Nameless FP/OP's resonator essentially doing its job trying to keep the drone down. I switched to a JDL Ultraquiet Catted/Resonated FP/OP and the resonance went away in exchange for some added drone in the cabin. Turned out to be a non-issue, it was simply the front pipe doing its job.
Old 06-16-2020, 07:50 PM   #27
Ernest72
This is my setup, but I have some rasp. Wonder if it’s my Q300 exhaust that is getting louder overtime.
Old 07-15-2020, 10:28 PM   #28
Compelica
Compelica's Avatar
Drives: 86 GT
I just swapped from a stock OEM header to a gutted OEM header and I'm getting this noise as well. Seems like it's only happening when on a drive and not when revving in neutral, though.
Compelica is offline   Reply With Quote
Will header cause rasp? Tysoncrosby21 Engine, Exhaust, Transmission 8 02-12-2017 04:09 AM
Help with rasp (overpipe and catted front pipe) finch1750 Engine, Exhaust, Transmission 15 09-15-2016 06:07 AM
UEL + OP + Catted FP + OEM catback = abnoxious rasp? sw20kosh Engine, Exhaust, Transmission 32 08-30-2016 10:16 AM
Exhaust question, Rattle or Rasp KungFuWaffle Engine, Exhaust, Transmission 7 07-05-2016 09:11 PM
RASP noise after Header install ANYONE?? Squido3J Engine, Exhaust, Transmission 5 04-02-2014 06:46 AM
